I have a maytag neptune washerModel no# MAH5500AWW not draining and spring real slow?
  • 957 Answers
When it is not draining the first thing to do is to check the drain itself. locate the pump it will be on the bottom of washer, there will be a hose that runs from it. follow the hose and it connects to a cleanout u may have to disconnect the hose to make sure it is not blocked. check the discharged hose as well. if everything is clear then u my have a bad pump. when u turn on washer do u hear the pump come on to try to pump out water? the reason it is spinning slow is because there is still water in the tub.
Posted on Apr 17, 2014
  • 156 Answers
SOURCE: Maytag Neptune Washer Boot Drain 12002533 installation
its is hard to do if you have some one to help makes it easer to hold on put a thin piece ribbben strong and then pull it will go on
Posted on Feb 29, 2008
  • 8 Answers
SOURCE: maytag neptune mah3000aww
re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Posted on Oct 23, 2008
  • 1294 Answers
SOURCE: i have a maytag neptune washer the water will not drain out of it
First drain as much water from the drum as possible and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter. Refit carefully after job is done. And fit outlet tube a correct height, not too deep. <courtesy tzotsi>
Posted on Mar 10, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Posted on Oct 04, 2009
digritz
  • 530 Answers
SOURCE: how do i fix nd code for mde5500ayw maytag neptune
There are two possible causes to the "nd" code. The first is with the pump itself. Either is is blocked or it is simply worn out and needs replacing. The second is a malfunction with the control board. Unless you find a blockage to the pump there is no way to know which one is the cause of the "nd" code without some testing or replace these items.
If you are unafraid of facing your washer with tools in hand then you should be able to test the pump. As for the board, all you can do is check it for damage most likely caused from a component melt down. In which case it's going to need replacement.
But check for blockages first because that will cause the "nd" code.
I hope this helps and good luck.
Posted on Oct 06, 2009
Why is my maytag Neptune Model no# MAH5500AWW spinning very slow and not draining water out?
Complete drain must occur before spin. A no drain situation would be an actual full pool of water seen in the bottom of the machine if all the cloths were removed, sounds like you are experiencing a spin enable switch failure, which mainly prevents final high speed spin leaving the cloths dripping wet. The spin enable switch contacts become tarnished/corroded over time resulting in poor connection. If the door lock light comes on than your door lock wax motor is working. The spin enable switch is the last switch to the right in the door lock unit where the light bulb is. Part# is 22002162. If there is an actual pool of water in the bottom of the machine as if you simply removed the cloths from the unit but left the wash water, than you should look first look to your drain pump for failure, or obstruction of foreign objects, or excess lint in the pump. Pleazer Appliance...
74bd738b-53cb-465a-99c1-ba55e2189ba2.jpg 5e1e4646-e2e3-4e7c-afc7-7a0e188e6cf0.jpg
Apr 15, 2014 | Washing Machines
MAYTAG NEPTUNE WON'T SPIN OR DRAIN
If it can't drain, it shouldn't spin. Pump blocked? Broken pump? Level sensor broken?
Sep 05, 2012 | Maytag MAH6700AWW Neptune Front-Load...
I have a Maytag Neptune fron loading washer and am getting an "nd" error code (indicates draining problem). I drained out as much water as I could by disconnecting the hose and running a wet/dry...
hello, yes the balance ring is liquid filled. The spring is hard for us as techs to get on too. I lock a pair of vise grips onto one end of the spring and pull it downward and pop it on.hope this helps
Jun 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
Can you replace the outer tub bearings on a Maytag Neptune Model FAV6800AWW
yes you can but will warn you it is a small project to do... the unit will require to be dismantled in order to get to the outer bearings... the lower unit taken apart and tub springs, drain hoses and taken out of machine to access everything... can be done but is about a 2 hour project if it is your first time to do it...
Jan 30, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Neptune MAH5500AWW make noise like metal rattling
may have something in the pump or one of the struts off
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAytag Neptune Drains Slow
perhaps there a clog in the draiin line or ive even sen where a coin will lodge itself in the opening of the hose in such a way that it acts a s a stopper valve rotating open and closed, be sure to look down / blow the lines clear
Nov 10, 2008 | Washing Machines
Can I eliminate or at least shorten the delay on the door lock feature?
unfortunately there is no way to elimate the wax motor.do not try to jump it out,you will blow the control board.
Sep 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
