Dell 926 All-In-One InkJet Printer Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell All in One 926 won't print from Vista
Computer no longer prints. The scroll menu on the printer only gives me the options of fax, menu, copy, etc. but no "print" option anymore. My computer still recognizes the printer, though... Any thoughts?
Michael Grey
Level 3:
  • Dell Master 365 Answers
  • Posted on Jun 18, 2009
Michael Grey
Dell Master
Level 3:
Answers
365
Questions
Helped
132649
Points
1137
Go to the control panel and select printers.See if it there and set as the default printer.
1helpful
What mode does 926 Printer must be in to print?
For printing from the computer, I beleive it is 'copy' mode.
4helpful
3answers
It does not print alignment test page can you email me one ?
How to Align a Printer Cartridge for a Dell Photo AIO 926Printers capable of producing high quality graphics and photos, like the Dell Photo All-In-One 926 printer, must have their cartridges properly aligned for best results. Typically you only need to align your printer's ink cartridges immediately after replacement. However, if documents show signs of uneven lines the cartridges being out of alignment. After aligning the cartridges print a test page to check print Instructions 1 Load printer paper into the Dell Photo 926 printer 2 Click on the start menu icon, on your computer, with your left mouse button. Left click on "Control Panel." Left click on "Hardware" and then left click on "Printers and Devices." 3 Locate and double left click on the icon for the Dell Photo 926 printer. The printer control window will open. Double left click on the "Adjust Print Options" button. 4 Click on the "Services" tab in the printer's window menu bar. Double left click on the "Align Print Cartridges" button." Left click on "align." Wait for the "Parameter" page to print. 5 Compare the figures on printed parameter page to current settings in the "Align Print Cartridges" window that has popped up on the computer. If the figures on the printed page correspond to the figures displayed in the window the cartridges are in alignment. If the figures on the page do not correspond with the figures in the window you need to set new parameters. Enter the new figures from the printed parameter page into the fields on the align print cartridges window on the computer, as directed by the prompts. 6 Click "Done" or "Okay." Exit out of all menus. Print any document and check the text and or graphics for quality.
2helpful
I am trying to get my hp 6500 all in one machine to STOP printing faxes that are being saved to a file on my desktop. it is supposed to only print the color faxes and save the black and white faxes to a...
You need to disable or turn off the Print Fax option from printer setup menu.
Press Setup button on the printer front panel ( ranch like symbol )
Scroll till you find Basic Fax settings - Press OK
Scroll till you find Fax to PC - Press OK
You will find option Print Fax - Press OK
Turn it OFF
Exit the Setup and The printer will no longer print any B/W faxes except for Color.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
3answers
1helpful
I cant find my print option on my printer, i see scan, copy, maintanence , fax no print
man this because the print command only be given from computer/ any device which contains file
1helpful
My Dell Photo 926 stopped printing in color. It prints in black and white. If I make a copy, it can still make a color copy. I'm stuck.
hi ,
if u can make a copy in color , rest assure ,nothing wrong with the printer .
it s only needs a setting change to be done .
is your pc running on xp r vista ?>
if xp : click start-->run-->type control printers --> your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
if vista : click start ---the cursor would flash on "start search "...typre printers and press enter key ...then ..your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
2answers
Says it's printing but it's not
Go to your "start menu" and look for "printers and faxes" then after that it should bring up a screen with your current printers and faxing machines. Make sure your Dell 926 InkJet has a little black check by it. If not then right-click the Dell InkJet and select "set as default printer". If it already is, then right-click it again and make sure it isn't paused. It will give you an option to "resume printing". After that then it should work. Make sure to also delete the old printers that may be on the computer too, the reason is because it may block out your other computer.
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Dell 926 printing freezing when using remote desktop
I've had a problem with a 926 freezing at the end of printing when deleting the job from the print queue.This was as a local or network computer/printer task.I changed the print processor to winprint/NT EMF 1.008 and this cured the problem.Right click on the printer/properties/Advanced/Print processor and give it a try.HTH.
(Using Vista Ultimate)
Can't print
Step 1. Go to Control Panel--Windows updates; click Check for Updates--Windows is sending updates for different printers. If there is one install it. See if that takes care of the problem.
If not, go to Step 2.
Step 2.---Turn on the Printer---go to Control Panel---Device Manager. Under device manager look for any yellow exclamation point, if there are any under "Imaging device" or Portable Devices, then there is something wrong with the driver. Go to www.dell.com at the top type in 926 printer, the next page click on the first result "Install Dell 926 All-In-One Printer Drivers. Follow the directions one by one, start with the first and work your way down.
Also,
There is a firmware update release 1/6/2008 for the Dell 926
Go to www.dell.com home page. Go to Support and Help in the middle of the screen, put the cursor over it and click Drivers and Downloads; next screen identify your model: Select Model-Printer; select you product line--click on Printer; next page Select you Product Model 926 (Personal All-In-One) click on it;
then confirm Under Printers click the plus sign and it will give you 4 options, choose the firmware option. DO NOT INSTALL THIS FIRMWARE UNDER YOU HAVE TRIED EVERYTHING ELSE. SOMETIMES FIRMWARE CAN MAKE DEVICES INOPERABLE.
GOOD LUCK.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
