Question about Frigidaire Clothes Washer Vane - 134657000
REMOVING FRIGIDAIRE WASHER VANE - Frigidaire Clothes Washer Vane - 134657000
3 Suggested Answers
  • 39 Answers
SOURCE: removing drum vane
You need to remove the inner and outter tub to replace this.It isnt for a home owner to attempt. Call a qualified technician for this repair.
Posted on May 22, 2009
  • 4088 Answers
SOURCE: Need directions to remove broken drum vane in a
Open the top of the machine (look behind the top for several screws to remove) and slide it back to release from the cabinet. This should give you access to the screws that hold the vane in place. Hope this helps!
Posted on Jun 28, 2010
Paddle in drum broke
Hi friend, thank you for your post!
Based off the information you have provided the paddle (vane) inside your Frigidaire washer broke. I would recommend having a technician come out to diagnose and repair your appliance due to some of these intricate parts requiring precision and patience. When replacing such components or removing them from your appliance I suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. Hope this helps. -Matt
Aug 12, 2014 | Frigidaire Washing Machines
How to remove Frigidaire water vane?
Good Morning Friend,
I understand you want to know how to remove the water vane on your Frigidaire Affinity washer, model# FAFW3801LW. I see that there is possibly a penny inside the vane that you can hear an feel as the drum rotates. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to take the vane off and remove the penny with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Affinity FAFW3801LW 27"...
Gltf530dso frigidaire washer
http://www.appliancepartspros.com/frigidaire-vane-131274600-ap2106479.html
This is the part. You have to remove all the panels, The drum counter weights and finally the drum. Then you have to remove the inner drum from the plastic outer drum. Once removed you can get to the screws that hold the paddles in place. Then put it all back together. It may be easier to call a repair man in your area.
May 23, 2014 | Washing Machines
How do I remove the washer paddle on my frigidaire front load washer
Hello - Generally speaking, there is not a paddle on a front load washer however there is a "vane" which is where the water comes out of. What issue is the unit experiencing exactly? Can you tell me if it is displaying any specific error codes? If I know more information on what the issue is, I can try to better assist you further.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
How to replace drum vane
I believe the vane needs to move forward to remove from tub, needs a lot of pressure to get it out. sometimes if you tap it with a hammer it will release. new one slides in pretty easy.
Jan 18, 2011 | Frigidaire GLTF2940ES Front Load Washer
How do I remove a tub paddle from the tub of a Kenmore front loading washing machine 417 41042000
There is a single screw holding each vane in place: remove it, then pull the vane towards the front of the tub. 2 of the 3 in my machine were stubborn: I pried the stubborn vanes forward by putting the handle of a hammer behind them, then pulling. There are 6 tabs on the bottom of each vane that slip into slots that are cut into the tub.
Nov 27, 2010 | Kenmore 44102 Front Load Washer
Need directions to remove broken drum vane in a Frigidaire Gallery Front loader washer (GLTF2940FS1).
Jun 28, 2010 | Frigidaire ATF6000ES Front Load Washer
GE front load washer does not drain completely so that the clothes are wet aat end of cycle
Probably something in the pump. From the pic, it's a Frigidaire... Take off the bottom panel and the pump is on the bottom on the right. Bail it out or use hose pinch0off tool on the sump hose, take the pump out and look inside. You may have broken a vane or three on the pump and will have to replace it. Get a large hose screw type hose clamp for the sump hose to the pump. The Corbin clamp it comes with is a real PITA to get back on.
Sep 30, 2009 | GE WSXH208A Front Load Washer
Removing drum vane
No! Remove the screw holding the vane and slide it towards you. It will then come out.
May 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Elastic eating front load washer
Check the inside drum vanes. Sometimes the vanes may crack and grab certain items.Next check the front of the drum and tub for any loose items like wires from bras or curtains sometimes these may get stuck in the drum or vane and cause this problem.Also check your soap make sure there is not alot of suds this is my number one problem with these machines.H.E. soap is best but watch liquid tide it's been sudsing alot.
Oct 03, 2007 | GE WSXH208A Front Load Washer
Frigidaire Clothes Washer Vane - 134657000 Logo
32 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
