Question about Ryobi Garden
Ryobi edger attachment will not spin but motor runs
Edger attachment will not spin but the weed eater works fine
SOURCE: Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Posted on Jul 25, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Posted on Jul 31, 2009
philschneide
  • 448 Answers
SOURCE: carburator will run motor but will not let it stay
Most of us, at one time or another, leave fuel in trimmers or mowers for too long a time without running them. This causes the fuel to gum up and block passages, etc. A good idea is to add a fuel stabilizer (available at almost any hardware store) to the fuel or fuel/oil mix that you use for your small engines. It will allow the fuel to stay viable for a much longer period of time.
If you decide to actually diassemble your carb, and you have a digital camera, I would advise you to take picture along the way unless you are very good at remembering where things go after you have taken them apart. You also will probably find limiter caps over the setting needles. Sometimes you can simply pull them off; sometimes it is more involved than that. I would simply try spraying a carb cleaner into the carb (with the air filter removed), letting it sit for a few minutes, then try starting again.
Hope this also helps.
Posted on Oct 07, 2009
  • 61 Answers
SOURCE: Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Posted on Apr 29, 2010
  • 64 Answers
SOURCE: MY RYOBI S430 WITH THE EGDE ATTCHMENT WILL NOT RUN
too much drag on the edger, try putting some oil or lubricant spray where the edger spins on the attachment.
Posted on May 04, 2010
Ryobi electric hybrid weed eater quit working.
are there weeds stuck under the trimmer head causing it to work too hard perhaps and even short cords if not heavy enough will cause problems and burn out the motor
Jul 18, 2015 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Gas powered weed eater/edger has no power (starts fine but attachements won't spin with any velocity
You need to check compression with a reliable 2 cycle compression gauge, not an automotive one. Probably should also be pressure and vacuum checked too.
Oct 05, 2014 | Toro Garden
Whrere would i buy parts for my weed eater
Ebay is a great place to purchase weed eater parts.
Aug 29, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Ryobi weed eater troubleshooting
Here is a video I found helpful.
https://www.youtube.com/watch?v=iMFUW6DJia0
Aug 19, 2014 | Garden
40 volt weed eater lithium battery - battery charged but wont work
The motor may have failed. Check resistance with a multimeter across the tool terminals with the switch in the run position. If it is open then the motor has gone bad or the switch failed.
Jun 05, 2014 | Ryobi Garden
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
My Ryobi weed eater will'not rev up and keeps dyeing
Normal reasons for not reving are, blocked air filter, blocked spark arrestor in the muffler, or blocked exhaust port ( with carbon )
Feb 16, 2012 | Isuzu Rodeo Cars & Trucks
MY RYOBI S430 WITH THE EGDE ATTCHMENT WILL NOT RUN UP TO FULL SPEED. IT BOGS DOWN AND STALLS. RUNS FINE WITH THE WEED EATER ATTACHMENT. THANKS RON
May 03, 2010 | Garden
Garden Logo
95 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
