Question about Samsung Dryers
Samsung dryer dv203aew xac clothes are damp at the end of the cycle. Ducting & trap are clean. Sensor dry strips are clean and meter ok.Any advice?
catriver
  • 878 Answers
SOURCE: Whirlpool GEW9200LQ0 Gas Dryer
Andeb, 90% of the time long dry times are caused by blocked vents. If you are sure that this is not the case there are a couple of things to check. First check the sensor; press the more time button and less time button 4 times until 88 shows in the display.(more time,less time, more time, less time). Open the door and you will hear a beep and a see a code. On the inside just below the vent screen is the moisture sensor. Moisten your finger and lay it across the sensor strips covering both. If you hear a beep, the sensor is good. Sometimes they build up with fabric softner and need to be sanded lightly. Another issue might be the burner coils. Remove the bottom panel and check to see that the burner is igniting and remaining lit. Sometimes these coils become week and will not sustain the flame. I will attach a diagram, look at number 13 and 14 on the picture. These are the coils. Catriver..post back.
Posted on Sep 18, 2006
jsrock516
  • 5911 Answers
SOURCE: Dryer not completely drying clothes.
Cleaning the lint trap of the dryer may is not enough in some cases. I suspect you may have a problem with the vent ducting that extends from the the exhaust of the dryer to where it exits your home. The majority of dryer heat realted problems are due to poor ventilation and clogged vents. I dryer left in this condition will overheat to the point of failure. Not to mention, this creates a fire hazard and a habitat for rodents.
A simple test to determine if you have a dryer ventilation problems is to remove the vent hose from the back of the dryer and attempt to dry a load WITHOUT the vent hose attached. The air exiting the back of the dryer should be warm and forceful. If the clothes dry normally, then you need to inspect your vent ducting from where it enters the wall, to where it exits the home.
If the air flow is weak and your clothes still take a long time to dry, then you need to inspect the INTERIOR ducting of the dryer. Namely, the air blower housing. I suspect you'll find your clothes will dry better with the vent hose removed. Since it dried normally BEFORE you moved, and now it doesn't, you need to take a serious look at where the vent exhausts to. If the ducting runs through and attic or crawl splace they typically development sags, kinks and can clog. The rule of thumb when it comes to ducting: the SHORTER and STRAIGHTER, the better. Every bend you put into a dryer vent creates resistance to air flow, makes the dryer blower fan work harder and creates choke points where lint can accumulate and clog. Perform this simple prelimnary check and let me know what you find. I hope you find this advice helpful.
PS Do not run your dryer for extended periods of time without the exhaust hose attached. This will add humidity to your home and potential mildew. One load should be enough to determine if you have a problem. Don't run it this way as a normal everyday routine.
Posted on Sep 08, 2008
  • 85 Answers
SOURCE: Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Posted on Dec 16, 2008
Maytag317
  • 1136 Answers
SOURCE: dryer heats up but clothes not getting dry after several cycles
Hi, First thing you want to check is the 4" vent that goes to the outside. Make sure that it is clear of lint and that it is no pinched or kinked at all. Is this electric or gas dryer and what model is it?
Vic
Posted on May 17, 2009
  • 212 Answers
SOURCE: dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Posted on Jun 24, 2009
Tip
SENSOR DRY IN SAMSUNG DRYERS
As a tech, I'm constantly fielding questions about loads of clothes not drying properly in the larger Samsung dryers--and this tip can be used for a lot of dryers with the sensor-dry feature. Sensor drying uses a pair of metal strips located on the filter holder or on the back wall in the dryer. When wet clothes rub against the strips, this sends a signal to the main board which tells the dryer to keep going. Unless large loads are used, the consumer should use "timed dry". This is because smaller loads won't hit the sensor strips often enough and cause the computer to count down too rapidly. Also, consumers should try to make sure like items are placed with like items( shirts with shirts, pants with pants, towels with towels, etc) Thick clothing(jeans, heavy sweatshirts, etc.) usually will have damp spots like pockets due to the moisture not being able to contact the sensor strips--the technology is not 100%. Also, if there are problems with the timer starting to count down too rapidly all the time, and dryer sheets are used, the sensor strips may be coated with a waxy layer. Use some super fine emory cloth to polish the coating off of the sensor strips. You very well might find that the problem is solved and not have to initiate a service call!
on Sep 08, 2015 | Samsung Dryers
Why is my clothes still damp
sensor has wax buildup on it Dryer thinks clothes is dry. Shuts down. Get busy cleaning the sensor strips with windex or 409 The strips are located inside the dryer below the filter on most models. The way it works is wet clothes rub the sensor strips which discharges a capacitor on the dryness sensor board. As long as the capacitor is being discharged from the wet clothes the control knows to keep on a truckin. if no moisture is sensed then the capacitor will achieve a full charge and the control will proceed to end of cycle after a cool down period. Clean the sensor bars and party on.
Jan 04, 2013 | Dryers
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
Hi super capacity dryer - tumbling ok, apparent hot air when door is opened, but clothes still damp after about 90 minutes of drying time..also no visible lint in lint trap..? any suggestions? thank you
ventilation problem,disconect hose from back of dryer make sure lint trap is clean turn dryer on clothes should dry,if they do your is bad or vent to house is stoped up
Jan 23, 2011 | Whirlpool Dryers
My dryer turns, but it doesn't dry my clothes. After drying several time they are still damp
, your vent duct is probably obstructed (it happens over time). If your model is the type where you could feel air if you removed the lint trap, do so and turn the dryer on. If you get warm air there... you know it is in the ducting, in the back of the machine, or at the wall vent. Pull off your duct, and give it a good cleaning. Clean out the back of the machine, and the wall vent. When you reinstall the ducting, minimize any twists and turns possible.
If the coils are good, but you get no heat, the problem may be the thermostat or the motor switch.
Aug 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dec 13, 2008 | Maytag PYE2200 Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Sep 08, 2008 | Whirlpool LER4634J Electric Dryer
Dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
Dryers Logo
26 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
