Question about Coffee Makers & Espresso Machines
Alessi rs07 bottum plate
I have an Alessi 9098 stainless steel pepper mill given as a wedding gift. It fell from a table and the blue fin broke. Is it possible to buy the blue fin? If so, how would I go about it?
Yes! you can get the part here:
http://www.connox.com/categories/spare-parts/replacements-alessi/spare-parts-alessi-pepper-grinder.html
Its 6 euro
Feb 06, 2013 | Alessi 9098 Pepper Mill
We have an 8 year old Alessi Nespresso machine, and it is leaking water at the base. It seems to leak only when the machine is in use. There is not any water at the base of the water container, so i am...
I have the same model, same age, same problem. It appears to be the seal between the metal heating coils, and the plastic switch that selects steam or coffee. Possibly caused by no cleaning the injector hole with the tool provided with machine (which causes a lot of back pressure). On mine, the screw that holds the switch to the heater has corroded and can not be unscrewed, so not possible to access rubber seal, and repair. May be tricky since this is plastic sealed to hot metal with a rubber gasket. So fo now, i unscrewed the black base plate on the bootom, and set the Alessi in a tray. THen just wipe up water after use.
Dec 27, 2010 | Microwave Ovens
How to change a belt
look on the bottum of the machine you should see 4 screws there should be arrows next to them remove them and pull the base plate off remove the old belt put the belt on the drive shaft then put the belt on the upper wheel it might be a little hard but just roll it on useing the wheel
Jun 28, 2010 | Hoover U5018-900 Bagged Upright Vacuum
I need to know what parts are missing to my 9090 espresso pot . It has the top and bottom sections, the pressure valve and the funnel basket but no washer. is there anything else I need to make it...
The 9090/6 designates the 6-cup (30cl) model. In metric it is designated as 20.5cm (~8") high by 12.5cm (~5") in diameter. The washer holds a metal strainer disk (which you may be missing) to the underside of the top piece. You can buy washers--and maybe strainer disks--from Alessi stores. Check the Store tab on www dot alessi dot com.
Nov 02, 2009 | Alessi 9090/6
Alessi whistling kettle -- one whistle doesnt work.
you need to replace it with a new one it will be corroded. heat kettle then drive out pitch pipe with a screw driver from below, insert new one from above.
Sep 24, 2009 | Alessi Richard Sapper 9090/1
I need a replacement glass carafe for the alessi 9094/8 coffee press. Wher can I find one and how much should it cost? Thank you.
You can get a new carafe for the alessi 9094/8 and other 8 cup alessi coffee presses from Speranza Design Gallery www.speranzaonline.com . Search for 8003299015146 or go to this link: https://www.speranzaonline.com/store/prodView.asp?idproduct=2074 The cost is $24 plus shipping. It is genuine Alessi and it fits perfectly! I was very happy with my transaction with them -- easy web transaction, good communication, quick shipment, excellent packing of the fragile item. Comes in original Alessi box. It is listed as Alessi French Coffee Press Replacement Glass 8 cup .
Mar 02, 2009 | Alessi 9094/8 Coffee Maker
Need gasket for Alessi 6 cup stove top espresso coffee maker
I have a Elevation Espresso Coffee Maker it worked fine until today when it stopped heating the water. Any help would be great.
Regards
frank
Jan 21, 2009 | Alessi "Coban" Espresso Machine
Alessi coban rs04 espresso maker
Hi All,
I had the same problem. There is ONE authorised dealer for Alessi in Italy. They are Arthur Eugster Italia srl, in Asti (Piemonte). I don't have the contact number, but my friend in Italy got a complete set of seals from them, FREE OF CHARGE (don't ask me how he got it) and sent to me in Australia. Good luck
Fulvio
Jul 25, 2008 | Alessi "Coban" Espresso Machine
Coffee Makers & Espresso Machines Logo
19 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
