Question about Dell Dimension™ B110 PC Desktop
Dell b110 does not recognize more than 32 gb of hdd
    Master:
  • 569 Answers
Check the jumper settings of the hard drive
The drive is larger than 32GB, but the operating system only recognizes 32GB. If the operating system, BIOS or DiscWizard can only recognize 32 GB of the drive it may be caused by one of the following:
  1. Drive Jumpers: Applies to Mac and Window users. On drives that are larger than 32 GB there is a Capacity Limitation Jumper (CLJ), also known as the Limit Capacity Jumper or the Alternate Capacity (AC) Jumper setting. This jumper will limit the capacity of the drive to 32 GB and should only be used when the BIOS hangs when trying to auto-detect the drive. If you have two jumpers shunts on the drive you will need to remove the CLJ or AC jumper. If you format the drive with the CLJ or AC jumper then the drive capacity will be limited to 32GB. After removing the CLJ or AC jumper the drive will still be recognized as 32GB. You must reformat the drive without the CLJ or AC jumper to gain the full capacity of the drive. The other option is to create a second partition with the remaining unallocated disc space.
  2. BIOS: On older systems (pre- November 1998) the BIOS may not support drives that are larger than 32 GB. In the BIOS setup please set the drive type to AUTO detect. If the BIOS detects the full capacity of the drive then the BIOS will support the capacity of the drive. If not please perform one of the following:
    1. Check with the system or motherboard manufacturer for any BIOS upgrades for the system.
    2. (Recommended) Purchase a PCI ATA controller card that will support the capacity of the drive. The two benefits of ATA controller cards are:
      • The ability to support large capacity drives
      • The ability to support the faster transfer rates of the drive.
  3. Operating System: Windows have a 32 GB format limitation for FAT 32. That means if you formatted the drive in FAT 32 with Windows, the largest partition supported is 32 GB. You will need to format the drive in NTFS if you want to partition the drive larger than 32 GB. The other option is to create a second partition with the remaining unallocated disc space.
  4. Incorrect Reporting to the BIOS: The drive itself may be reporting the incorrect size to the BIOS. In order to correct this, you will need to download SeaTools for DOS, boot into the SeaTools disc, and run the Set Capacity utility. It is recommended that you only have the hard drive reporting the incorrect capacity connected to your system while performing the following steps. Any other hard drives should be disconnected.
    It is recommended that you back up any important data on the hard drive before using SeaTools to set the drive size. This is a potentially data destructive procedure. Seagate is not responsible for any lost data.
    After correcting the drive capacity, the drive may still show a partition size of 32GB but with unallocated space. You must delete its current partition then repartition and format the drive to gain the full capacity of the drive. The other option is to create a second partition with the remaining unallocated disc space.
    1. Insert the SeaTools for DOS CD or floppy disc into the appropriate drive, and restart your computer. When SeaTools boots up, carefully read the license agreement, and press Y if you accept it.
    2. Select the correct drive from the list using the mouse or keyboard.
    3. Choose Advanced Features .
    4. Choose Set Capacity to Max Native.
    5. Once the capacity has been set SeaTools has returned to the main screen, take the SeaTools disc out of the drive and completely power down the system. The system needs to be shut down so any cached information is cleared. If you simply reboot or reset your computer without completely powering it down first, the corrected capacity setting will not take effect.
REFERENCE TO THIRD PARTIES AND THIRD PARTY WEB SITES. Seagate references third parties and third party products as an informational service only, it is not an endorsement or recommendation - implied or otherwise - of any of the listed companies. Seagate makes no warranty - implied or otherwise - regarding the performance or reliability of these companies or products. Each company listed is independent from Seagate and is not under the control of Seagate; therefore, Seagate accepts no responsibility for and disclaims any liability from the actions or products of the listed companies. You should make your own independent evaluation before conducting business with any company. To obtain product specifications and warranty information, please contact the respective vendor directly. There are links in this document that will permit you to connect to third-party web sites over which Seagate has no control. These links are provided for your convenience only and your use of them is at your own risk. Seagate makes no representations whatsoever about the content of any of these web sites. Seagate does not endorse or accept any responsibility for the content, or use, of any such web sites.
dell b110 does not recognize more than 32 gb of hd - 24124485-qhuj4d4h5jjhjbfycqvsxzal-2-0.jpg
Posted on Nov 06, 2015
4 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: Dimension 4700 with Barracuda 500Gb SATA HDD
Windows XP installer will partition any hard drive with 10% open space. (system paration for recovery).
yes! it is acceptable. you will see 500GB but only have access to 475GB.
Posted on Dec 12, 2008
parjee
  • 83 Answers
SOURCE: dell dimension b110 not reading cd drive
Do you have any device drivers loaded on your system that may be interfering? Such as ANYDVD or some other app? Does this happen with data DVD's as well as movies?
Have you tried starting your DVD player application and then inserting the disk into the drive?
One thng you may want to try is going into device manager and deleting all IDE devices, then deleting the IDE controllers themselves and rebooting. This should allow Windows XP (I assume it is XP) to re-recognize and re-initialize the hardware. Then you may want to try re-installing the motherboard chipset drivers (there should be a driver disk that came with your machine, hopefully) just to make sure they are all in good shape.
Posted on Sep 23, 2009
  • 457 Answers
SOURCE: Is 160 GB hard drive maximum size for Dell
No, you should be able to put in any IDE hard drive, actually a total of four drives should be possible, including DVD / CD/R drives.
The machine has only one internal 3.5" and two 5.25" drive bays, though, so you would need to find a way to mount the extra drives in the case.
Posted on Feb 11, 2010
Dell dimension 4700- added 2gb module in memory slot one, color coded white, and added 2gb module slot 3, also color coded white. only 2 gb recognized by computer, the second module is not recognized. ...
This motherboard uses inter-leaved RAM and RAM needs to be installed in pairs.
Check the BIOS RAM settings.
Try and use the same make of RAM.
One of the RAM modules may be faulty.
Try inserting the RAM module that was in slot 3 to slot 1
Feb 19, 2011 | Dell Dimension™ B110 PC Desktop
I have a Dell Dimension B110 and it only detects 256 mb. I have installed a WD 500GB hard drive and installed 2 - 1 GB RAM and still nothing. I think I need to change the BIOS but don't know how.
Yes, you need to change your bios setting. The best thing to do is the reset the BIOS to default and check your system after the reboot. Good Luck
C2S.
Aug 21, 2010 | Dell Dimension B110 PC Desktop
Does a 80 gb hdd require a bios update for this computer
Hi:
Your computer will support an 80 gb hard drive. It will recognize up to 137 gb, and you could actually install a 160, with the included set up software that shipped with the new hard drive.
Apr 22, 2010 | Dell Inspiron 1000 Notebook
I have a Dell B110 and the system only recognizes 252Mb of memory. I thought I had a bad memory stick so I installed 2-512 chips. Now System Info shows the 1024 with only 100 available. Task Manager only...
Try to seat one memory first than try the other one. One of them might be defected. Also check the memory slots, ensure they both work well.
I had 2-512mb sometime system just detect 512 and other time 768. Since I replace both with new memory cards they work just fine.
Apr 13, 2010 | Dell Dimension™ B110 PC Desktop
Is 160 GB hard drive maximum size for Dell Dimenstion B110?
As long as you have Windows XP with service pack 3 or a newer version of windows installed.....there is no limit on capacity. Go with the biggest and baddest there is.....
Feb 11, 2010 | Dell Dimension B110 PC Desktop
Dell dimension b110 not reading cd drive
Sep 23, 2009 | Dell Dimension™ B110 PC Desktop
How to add extra memory card in the mother board
well u may upgarde your ram to 1 or 1.5 GB if less ... and try installing Windows 7 on your computer i can tell you how to download or if you already have ... then the speed will not bother you any more...
Jun 23, 2009 | Dell Dimension™ B110 PC Desktop
Mainboard not reconizing my hdd
check to see if your ram has not losse, had the same problem with a mates computer.
Jul 03, 2008 | Dell Dimension B110 PC Desktop
Dell Dimension™ B110 PC Desktop Logo
32 people viewed this question
Alun Cox
