Question about Epson PowerLite® 83c LCD Projector
Projector overheating projector says it is overheating
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
3M SCP712 projector shuts down after an hour--can't turn back till it cools
Hello
the problem is with overheating. Look whether the cooling fan doesn't work or air filter is cloggy with dust. OK.
Nov 08, 2011 | 3M SCP712 Projector
Turned itself off, can't reset.
Have you been using this projector for some time?
With time, dust gathers in 'air filters' and it hinders the movement of air though the projector. When this happens, projector gets overheated. To prevent damage, it shuts off automatically.
You haven't given much details, but if you think overheating is the problem, open the top cover and clean dust, specially from air filters.
Sep 25, 2011 | Sharp DT500 DLP Projector
My 3M S20 PROJECTOR HAS A BIG YELLOW SPOT
seems like the blue polarizer is overheated. you would have to check out inside the optics to see if the light that enters the blue lcd is coming from the overheated glass plate just in front of it.
Apr 04, 2011 | 3M S20 Multimedia Projector
New bulb, fan working, after 10 mins of operation get posterized image; suspect overheating; dust has been cleaned out; has not been taken apart
Hi!
Is the projector placed in a box or an area where it could generate overheating? Is this projector still within warranty?
Please feel free to update me. Cheers!
Feb 04, 2011 | Optoma TX1080 Projector
Sanyo PLV 60 HT keeps on overheating even after I cleaned the
hi dear plz check the projectors fan. It is working properly or not
Jan 31, 2010 | Sanyo PLV 60HT Multimedia Projector
Acer Multimedia Projector PD100 DLP overheating problem
blow the dust out of it with canned air, make sure the fans are all spinning. this should remove the causes of overheating. if it still says that it is overheating, replace the thermal sensor (usually near the lamp or the lamp fan).
Jan 12, 2010 | Acer PD100 Multimedia Projector
Overheating problem
clean out the projector with canned air. the dust keeps in the heat. also check the fans and see if they are working.
Nov 11, 2009 | Office Equipment & Supplies
The projector is starting up but after warming up it shuts itself off. It is not the a problem with the filter, lamp seating or an overheating issue.
Does the lamp actually light up and project? If not, it's probably a dead bulb. Are there any flashing lights that might be displaying an error code? How dow you know it's not overheating? Remove the filter and give it a good cleaning. Some projectors measure airflow and, even though the heat hasn't built up, the projector shuts down because it predicts overheating will occur due to insufficient airflow.
Aug 04, 2009 | Sharp Notevision XG-P20XU Multimedia...
Projector overheating and turns off after 20 mins
I have a HP VP6111 projector that works fine on a table top but overheats ( overheating ) when turned upside down and hung from my ceiling. My solution...I went to Circuit City and bought two 80mm computer fans. I also purchased a 12V power supply from Radio Shack. I put one fan on front of my projector and the other on the back of the projector and wired them into the 12V power supply. I mounted both fans with velcro. The front fan pushes air and the rear fan pulls air. The projector now runs fine without shutting off. The fans are 12V and push 34 cubic feet per minute of air. I am very happy with this solution.
Oct 25, 2006 | Compaq Microportable 2810 Multimedia...
Epson PowerLite® 83c LCD Projector Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
