Question about Coleman Home Electric Furnace Eb15b/Eb15d
No fan when ac kicks on Ihave a eb15b funace with a coleman ac
The fan works when heat is on but not with the ac unit
    Master:
  • 571 Answers
The heat will normally use a low speed on the fan, & the AC along with the fan switch on the thermostat will use the high speed. The thermostat turns that high speed on when there is a call for cooling & is the same switch if you were to manually turn the fan from auto to on. Try turning the fan on @ the thermostat. If it works, then replace your thermostat. If it doesn't, it could be a bad fan speed, a bad fan relay on a control board or external relay, or a loose or broken green thermostat wire.
Posted on Dec 05, 2014
Furnace kicks on then shuts off
Coleman furnaces us a temperature delay with a temperature on around 130F to 150F and off around 110F.
If the inrush of cold air cools the delay below the off temperature the fan will go off until the heater heats it up to the on temperature.
Jan 06, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Coleman eb15b blower fan will not shut off
Hello, this will be a stuck relay for the blower. Trace wires back from blower motor and it will lead you to the culprit
May 11, 2010 | Coleman Propane Forced Air Heater...
The most common issue with this symptom and unit is a stuck blower relay.
Once the unit is reached temp and the heat elements stop the blower is to shut down when unit cooled. In your case the switchis stuck resulting in continuous fan.
Here is a manual that is real handy for troubleshooting electric funaces.
http://www.nordyne.com/Literature/359a.pdf
Mar 18, 2010 | Coleman Propane Forced Air Heater...
Coleman Home Electric Furnace Eb15b/Eb15d Logo
111 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
