Question about Kenmore 62622 Microwave Oven
Need dimension to replace a kenmore 665.68601892
What are the dimensions of a kenmore microwave with model number 565.66401690?
best bet is to take a tape measure and measure the width , the height and the depth, write down those measurements then go to an appliance shop and measure all those on display
Dec 09, 2015 | Kenmore Microwave Ovens
How do i replace my microwave with one that has same dimensions?
you shop and shop and shop till you find one that is real close .
Nov 18, 2015 | Kenmore Microwave Ovens
How many cubic ft. in a Kenmore microwave over stove model # 665-61612100
Just measure the inside dimensions of the unit in inches. Get the length, width and height then use this formula: (L x W x H)/12 = Cubic Feet
Feb 26, 2015 | Kenmore Microwave Ovens
I need to know the dimensions of a sharp r-1471 microwave. Mine has stopped working and I want to make sure the replacement will fit
29 15/16" W X 16 3/8" H X15 1/4" D (outside dimensions)
I copied this from my Sharp Carousel Operation Manual as I just
had to replace my 13 year old microwave.
Apr 04, 2012 | Sharp R-1480 Microwave Oven
10 yr old hotpoint Microwave model #RVM1325BW will not heat, vent,clock, touch pads all working.Hust no heat. If this needs to be replaced what model # should I get for the same dimensions?
I would say that your heating element has gone out. I don't know exctly what model you have, but I would guess it to be about 1.5 Cubic Ft., and a replacement would probably run somewhere around $150 to $200. There are many brands, but if I had no cost to consider, I'd probably go with a GE or Kenmore. Hope this helps.
Mar 18, 2011 | Microwave Ovens
What is the dimension for my fridge. It is Kenmore style #106.56873602? We are rebuilding the kitchen and my cabinet maker needs to have the exact dimension. Thank you! guylaine
Isn't it better that the designer of your kitchen takes a first hand measurement of the fridge so that the tolerance is given on the sides so as to accommodate for the heat exchange, waste water tray removal and the electrical connections.
I would like to recommend that the tolerance must be good enough according to the temperature of your place.
Feb 14, 2011 | Kenmore Microwave Ovens
What are the dimensions for a Whirlpool Microwave MH7100XYB? Whirlpool doesn't have the dimensions on their site and I'm trying to replace it.
30" wide x 16" tall x 14" deep. Tried to find a replacement for mine of that size with no luck. Turned out a $30 capacitor needed replacing ($90) service charge.
Sep 21, 2010 | Microwave Ovens
Need to replace broken glass plate for kenmore elite microwave model number 565.61584011
The tray used to be part number 16264 but it's no longer available.
That model oven was made by Sanyo.
If you have the old one, you can contact Martin Microwave with the dimensions and they may be able to find a suitable replacement.
Jul 02, 2010 | Kenmore 63792 Microwave Oven
I need vent dimension for Kenmore Microhood combination model #8162. Is the vent at the back 3x10 or 3x12?
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View Manuals" button.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside. This is where you will find that information.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Dec 16, 2008 | Kenmore 63763 Microwave Oven
Kenmore 62622 Microwave Oven Logo
74 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
