Question about Stihl Br 500 550 600 Backpack Blower Throttle Cable Assembly 42821801100
My throttle cable broke at the carb how fix with out buying one
Get one from an old bike ...
i would if you need just the end fixed use a choc box connector
used for connecting mains wires etc together
has two screws
strip off the plastic and you have a small bar with two screws
that can retain the cable inner
Posted on Dec 04, 2014
I have a '74 yz80a and i broke the throttle cable, you can buy one, does anyone know of one that will work? Does anyone know of a carb that i could use that would eliminate using the oem cable?
Getting a new carb is kinda like buying a new pair of shoes because the laces on your old ones broke, except you don't know what size of shoes you got.
A new carb will be expensive, difficult to set up properly for your current bike, and require weeks of testing. Not the best idea.
You should be able to find a cable that will work with your current carburetor. Bring the old one into the shop and simply compare lengths and the metal buttons on the end of the cable.
Jan 15, 2015 | Yamaha Motorcycles
I have a pw 50 dirt bike the throttle and choke cable are broke will it still start
Your question?
Replace cables & adjust carb.
Enjoy the bike!
Jan 08, 2015 | GAS Motorcycles
My throttle on my 1987 honda accord lxi hatchback is stuck.
I'd check throttle body/carb for stuck/broke parts..carbon buildup..
Also look and see if throttle cable got stuck somewhere or rusty and not sliding properly
Sep 12, 2014 | Cars & Trucks
How to replace control cable on a cub cadet
buy new cable the match it to old one throttle or chock cable you will have to remove breather then look how cables or mount reminder how there mounted unhook them if throttle cable you will have to remove carb 2 bolts are nuts loose carb twist it to remove throttle cable carb has to be almost off to twist it then remove cable at dash pull out replace cable with new one install in reverse order paying attenion how to hook up not straight forward you can do it
Aug 29, 2014 | Garden
Idle speed control
Cable is bad or spring at carb or throttle
body is broke, remember something is causinh
butterfly at carb/throttlebody not to retract
Jun 01, 2014 | 1994 Mazda MX-6
Stihl FS200 repair manual
I just saw this deal on the Fs200 Stihl Brushcutter. Equipped with a Zama c1qs51 carb. Junk the carb. Go to a stihl dealer and buy a three screw chainsaw type carb with a high low and idle screw. The c1qs51 is junk.The three school carb will put an end to your worries. Of course change your fuel filter naturally. I guarantee this will fix the thing. I own an Fs200 and Fs250.
Jul 15, 2012 | Garden
Engine cycles high & low, does not run smooth
I think the gas needs to be changed or the carb needs to have the needle and float replaced. The gas may be just strong enough to fire but misses causing the high and low. If gunk gets built up on the float, then the float can't be "floated" right to open up the needle so the right amount of gas is let in. Sometimes the carb, can be cleaned but it's usually best to just buy a new float kit, which is $5-$7 here. You can also buy a new carb which is about $35. Just depends on where and how you want to do it. Good Luck
Apr 11, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
Fuel enrichment knob broke i have new cable but manuel does not explain procedure
To replace the enricher cable on the stock Kiehen CV carb, you must remove the carb from the engine.
Remove the air cleaner cover, air filter, and backing plate. To get the backing plate off, you must remove the two large union bolts that go to the heads on either side of the ari filter backing plate and the three smaller bolts at the mouth of the carb. Loosen the adjustment of the throttle cables at the handlebar throttle grip. Take the nut off the backside of the enricher cable and it fall loose from it's bracket. Disconnect the fuel line from the carb, make sure the petcocik is turned off. Now, twist the carb slightly and pull until it comes out. Make sure you guide the enricher cable out. Once you get the carb out far enough, remvove the throttle and the idle cable from the carb and bring the carb on away from the engine. Now, use a 14 mm wrench to unscrew the enrcher cable from the carb. You'll have to change the elbow, nut, spring, and needle from the old cable to the new cable and reinstall it on the carb.
To replace the carb, guide the enricher cable back between the cylinders. Reconnect the throttle and idle cables on the carb. Replace the intake manifold seal (round rubber boot on the intake manifold) and lubricate it with a bit of silicone spray or something. Push the carb as far as you can into the seal. Reconnect the fuel line and adjust the throttle cables. Make sure you don't get them too tight and that the throttle works like it should. Replace the air filter backing plate, air filter, and air filter cover. Put the enricher cable up into it's bracket and tighten the nut on the backside. Be very careful tightening the nut as the plastic housing breaks easily. Tighten the nut just tight enough to securely hold the cable. Check the operation of the carb and make sure it operates smoothly and correctly. Now, you should be ready to ride.
Good Luck
steve
Apr 10, 2011 | Harley Davidson XL 1200 S Sportster Sport...
Idles at full throttle
Be sure the throttle cable is routed correctly and is not being stretched. When disconnected from the carb, does the inner throttle cable operate freely? Lubricate it. Also check that the cable connections at throttle and carb are seated properly. Does the slide move up and down freely? Remove the air filter and twist the throttle while looking inside the throat of the carb. LIGHTLY seat the throttle screw and the air screw then open each of them one and one half turns outward.
Aug 02, 2009 | 2002 Honda CR 250 R
Changing the speedometer cable
Assuming it's the same as my Kymco Agility, it's really easy cheapest is to buy a new one on ebay, it connects under the right handlebar to the throttle, there's a clip under the handle clip it in rescrew on the throttle handlebar and feed it through to the carb, just feed it through where the old one went and connect it to the top of the carb and that's it.
Nov 27, 2008 | 2005 Kymco People S 200
Stihl Br 500 550 600 Backpack Blower Throttle Cable Assembly 42821801100 Logo
94 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
