Question about Ruud UBHC Air Conditioner
The hose leading from the condencer to the house freezes up and wont cool the house??
    Sergeant:
  • 340 Answers
Low on freon , dirty unit clean evaporator and condenser. Tom
Posted on Jun 18, 2009
Where is thermostat on 06ford escape2.3 4cylinder howto remove and replave
the thermostat housing is at the lower radiato hose that clamps onto the thermostat housing. With engine cool, drain fluid from radiator. The lower house is held on with a clamp. Un tighten hose clamp and remove hose.Unbolt thermostat housing and remove. Remove thermostat Clean housing and thermostat seat. Insatll new thermostat and gasket, with gasket sealer, and tighten thermostat housing.Reinstall hose and tighten clamp. Refill radiator with anti freez coolant.Start engine and let warm up to normal Check the heater temp. If heat is good, shut off engine and let cool down. Re check coolant level and fill if needed.Also when running, check for any leaks at hose and thermostat housing. If all checks good, YOUR DONE.
Oct 21, 2014 | 2006 Ford Escape
WHY does it not cool for more than 10 minutes, than shutsoff
low refrigerant charge look at the sight glass if you see bubbles your low on freon. check your condencer coil outside clean the coil with condencer coil cleaner spray on wait 10 minutes hose off. most times a dirty condencer coil is the culprit
Jul 28, 2014 | Carrier 519exx042000aaaa 3-1/2 Ton Ac/hp...
Replace thermostat
follow upper radiator hose to aluminum housing this is where the thermostat is. be sure engine is cool remove radiator cap or reservoir cap if no cap on radiator disconnect upper hose from thermostat housing. remove two bolts in housing and remove housing. replace thermostat and reassemble. when finished refill anti- freeze leave cap off and start vehicle with heat on high. run the vehicle like this until air stops bubbling out of coolant and heat is hot steadily. continue topping off coolant during this process and be sure cooling fans engage before completion. then youre all done
Sep 19, 2012 | 2000 Pontiac Grand Prix
How do i change the thermostat in my suburban
Make sure the motor is cool you can drain down some antifreeze from radiator or slowly remove top radiator hose remove the bolts holding the housing remove housing remove thermostat clean block and housing install new o-ring or gasket which ever it has install new thermostat bolts hose re-fill radiator start let warm up check for leaks and add anti-freeze if needed.
Jan 21, 2012 | 1996 Chevrolet Suburban
Need to find the location of the thermostat on 2001 Cadillac Catera or diagram of its cooling system
First make sure and drain the water/anti freeze out of the radiator. ( be careful with the antifreeze you drain out because it has a sweet taste and is extreamly toxic and will kill any animal that finds it including you.) Just look at the radiator and you will see a large hose made of rubber. Follow that hose to the engine . The thermostat is under the housing that the hose is attatched to. Loosen the hose clamp and pull the hose off , that way you can see the thermostat down in the housing.
Jul 10, 2011 | Heating & Cooling
How to replace thermostat on 1997 dodge stratus 2.4 litre engine
Follow the top radator hose to where it connects to the motor. On my 97 stratus you follow the top hose which leads to piece where the radiator cap turns on, take out the 2 bolts and underneath is your thermostat
drain radiator first before you begin anti freeze is poison to animals you will also wont to get a thermostat houseing gasket replace the old one use 50/50 anti freeze put new thermostat in the same direction as the old one bleed air out of radiator when complete
Dec 14, 2010 | 1997 Dodge Stratus
Need to replace thermostat housing in a 2000 pontiac grand am 2.4L. I know where it is but I need to know about any precautions and what is involved in the process,
Engine should be cool
Catch leaking anti-freeze from thermostat housing hose when disconnected (if any)
Good idea to always disconnect negative battery cable anytime working under hood for extended period
Clean old gasket of block
These come to mind.
Charlie
Oct 01, 2009 | 2000 Pontiac Grand Am GT
Water coming from bell housing.
If you are ABSOLUTLY POSITIVE this is where the Coolant is coming from the ONLY Sorce is Freeze plugs ,There are Usualy 2 Behind the Flywheel. Sorry For the BAD NEWS but this IS the only thing that can Leak Out of the Bell Housing, Transmissiou Must Come Out and Flywheel also, Once The Flywheel is OUT you will see the FREEZE PLUGS. Good Luck !! Please RATE ME !!!!!!!!!!!!
Mar 22, 2009 | 2007 Dodge Ram 2500 Mega Cab Laramie
Overheating
there are three hoses leading to the water pump. the biggest one oviously goes to the thermostat housing, but the other two are much smaller 1 inch hoses, one of wich goes on the water pump and the other on the thermostat housing. if you follow the hoses one will connect to the upper part of the overflow for the radiator after hitting a T in the lines, that hose connects to the thermostat housing, and the other goes to the water pump its self.
Jul 23, 2008 | 1989 Jeep Cherokee
Ruud UBHC Air Conditioner Logo
37 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
