Lexmark printer p315 needs cleaning
Leaves white lines on photos how do i clean the lexmark p315 printer
Printerguy
  • 31 Answers
SOURCE: error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Posted on Aug 21, 2007
SOURCE: printer isn'treading card
According to Lexmark's website, the printer will not read a memory card larger than 256MB. They specifically mentioned xD cards, but not cover the other types of cards. I have a 512MB SD card, and had the same problem, so I would guess it can't read anything over 256.
Posted on Aug 22, 2007
headstrong
  • 233 Answers
SOURCE: Epson Photo R265 Lines every 2.5 cm
clogged nozzle, run the clean head then test page in this order at least 5 times in a row, you should see an improvement on each test page, sometimes you need to keep doing this clean/print until the nozzle becomes unclogged, if you don't see a difference in the 5-10 clean/test page then you need a new head
hope this helps
Thanks for your rating
Posted on Jan 09, 2008
Tirzo
  • 94 Answers
SOURCE: White lines in print
Hi, since you've already try some basic trouble shooting to your printer such as head cleaning & ink cartridge replacement. There's a big possibility that the nozzle on that printer might be mis-aligned or clog by dried inks & contaminants. The possible solution that we can provide to you (asside from head cleaning) is printhead alignment. If issue still present after doing that solution, your printer may require service.
---->>> Tirzo
Posted on Jun 11, 2008
vegakitten20
  • 685 Answers
SOURCE: Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Posted on Jan 04, 2009
Printer will not recognise camera memory card hp p315 photo printer
Was your Lexmark P315 printer able to detect this particular memory card before? Try to re-insert the card - it could be due to a slight communication problem. Have you tried inserting a different known working compatible memory card into the printer's card slot? This could be due to faulty memory card.
Also, please refer to Memory Cards Supported by the Lexmark P315 Photo Jetprinter.
Jul 26, 2011 | Lexmark P315 Photo Printer with 2.5" LCD...
Hello,I haven't been able to use my printer for some time and the ink heads are blocked,can you help please?
To clean the cartridge via the operator panel, follow the steps below:
  1. Press the Menu button once. The Photo Menu will appear.
  2. Press the down arrow until Clean Cartridge (Press SELECT) appears.
  3. Press Select to begin the cleaning process.
  4. When the page has finished printing, press Stop/Clear to exit the Photo Menu.
However, if you have made several tries already yet cartridges are still not printing properly, it may be time for you to replace those old cartridges with new ones.
Source: How to Clean the Cartridge on a Lexmark P315 Photo Jetprinter
May 30, 2011 | Lexmark P315 InkJet Photo Printer
HI .I HAVE A LEXMARK PRINTER NO; P315, PUT IN A REFILL CARTRIDGE , BUT IT KEEPS COMEING UP WITH CARTRIDGE ERROR. I KEEP TAKEING IT OUT ,AND PUT IT BACK, BUT KNOW JOY , PLEASE CAN YOU HELP .
the issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again. But if you tried that and it doesn't work just call up their support number and check for replacement.
Jan 24, 2011 | Lexmark P315 InkJet Photo Printer
Jammed cartridge in Lexmark P315 photo printer
You may slide the cartridge.Its ok to do that, just slide to ur right.
May 28, 2009 | Lexmark P315 Photo Printer with 2.5" LCD...
P315 print cartrige error
What we surmised is that the little wire contacts on the print cartridge were bad. One suggestion was to use a pencil eraser over the area where the small wire dots are on the cartridge, then wipe clean with a lint free cloth. That didn't work either so I exchanged the cartridge and the problem went away.
May 14, 2009 | Lexmark P315 InkJet Photo Printer
Lexmark Printer model P315. Handbook Ref 310
According to the manual you can use 33 or 35
Do you need the manual?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Aug 30, 2008 | Lexmark P315 InkJet Photo Printer
Lexmark P315 connecting to Fujitsu Finepix S5100 Digital Camera
I belive Lexmark P315 only accept 256 mb cards at the largest
Dec 13, 2007 | Lexmark P315 InkJet Photo Printer
11 people viewed this question
jasbo
jasbo
