Question about Dell A425 Computer Speakers
Can I use the A425 speaker system powered by subwoofer on my HP laptop
    Problem Solver:
  • 14 Answers
Yes
Posted on Dec 22, 2014
2 Suggested Answers
SOURCE: speaker volume on one side extremely low
i have the same speakers.
but isntead of one side going,
both sides are dead.
and the light on the control side doesnt even turn on
it is plugged in
but i do not know what is wrong
solutions please?
darkhunter234@hotmail.com
Posted on Oct 09, 2008
Schematic Diagram for A425 amplifier
Did you ask Dell for help? Just don't hold your breath - they would rather you get a new one from them but U can try. If nothing, check it out on Google - might get lucky!
Aug 29, 2015 | Dell Powered Subwoofer Set A425 Computer...
Tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
on Jun 25, 2014 | Dell Zylux Powered Subwoofer - P/n A425
I need the driver for it, i have no sound
Anonymous,
There are no drivers for the A425 speakers. Make sure the power cable is attached to the speakers as well as the speakers plugged into the correct jacks. If your speakers are plugged in and powered on and u still have no sound; check to make sure the sound card drivers are installed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 18, 2015 | Dell Powered Subwoofer Set A425 Computer...
Dell a425 disassembly
I found this URL for you that shows a Dell forum where you could probably get all the info you need. It also has specifications for all the internals should you need to replace something. Good luck and be safe. I learned to hate capacitors a long time ago. :-) http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_E876EF53BCA3F058E030030ABD6260B2&isLegacy=true
May 23, 2012 | Dell Zylux Powered Subwoofer - P/n A425
A425 subwoofer, more bass? wires came off, no bass managment.
I wouldn't cross wires or leave one disconnected. Can you solder the wires back on the the control knob? Did you feel the subwoofer cone to see if it's working at all? I would guess the wire you didn't connect, is the subwoofer wire. Try putting it back to original cofiguration and solder the wires in place.
Jan 13, 2012 | Dell Powered Subwoofer Set A425 Computer...
How to open a425 subwoofer
pull off front plastic grill to access four screws on the speaker itself. Unscrew 10 screws on back to pull out the power board. The transformer is screwed to the bottom (4 screws).
Oct 01, 2011 | Dell A425 Computer Speakers
My subwoofer and speakers wont draw power when i plug it in, could it be the fuse or something else?
The Altec Lansing A425 doesn't appear to have a fuse. Check for a circuit breaker on any surge protectors it might be plugged in to and make sure they haven't been tripped. Confirm that the power cord is firmly plugged in. Additionally, you could check the wall transformer with a multimeter to make sure it is providing the correct voltage needed by the speakers. Check the back of the subwoofer for a hidden power switch. If everything is plugged in and turned on, but you still don't have power, you will either need to open the device up and troubleshoot it or replace it.
May 13, 2010 | Dell Powered Subwoofer Set A425 Computer...
Can i hook a sub woofer up to m-audio av40s
odwalxo, you can't add a subwoofer because the only output you have on those m audio speakers is for the "other speaker of the set via regular speaker wires". Everything else it's just inputs.
Apr 30, 2010 | Dell Powered Subwoofer Set A425 Computer...
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
102 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
