Question about Compaq Computers & Internet
Desktop with windows xp blue screen error code: stop: oxoooooo8e, (oxcoooooo5, ox804668a0, 0xf73ee8ec, oxoooooooo)de
Computer rebooted while i was on the web. Just shut down and rebooted. It came back with a blue screen and the error code above. It also said if this was the first time i saw this screen to go ahead and restart the computer. So i did and the blue screen came back. It said to try a system. Restore (f10) and it came back saying the system encountered a fatal error and needed to reboot. When it rebooted it came back with the blue screen and said try an f8 and reboot in safe mode. So i tried that but when it reboots the scree text is broke up and spaced u cant hardly make any sense of it. So i guessed at what i thot waas safe mode and the screen just kinda refreshes with the broken up text
  • 56 Answers
SOURCE: Blue Screen - indicating a problem
you possibly have a restore partition on your drive can you borrow a xp home cd from a friend if so let me know
Brian
Posted on May 26, 2008
dragon_sun25
  • 107 Answers
SOURCE: My Dell Dimension 4400 running
If that is not it reistall and to not loose you files click you partion durring the install and do not format it and click enter then click on leave partion alone
Posted on Dec 08, 2008
mwit465
  • 76 Answers
SOURCE: computer keeps rebooting.
Hi there, maybe I can help.
As your computer boots hit F8, go to the startup menu and disable "automatic restart on system failure". Boot up and make not of any error messages.
Let me know if this helps
Posted on Jan 03, 2009
LMITC
SOURCE: Blue Screen c000021a
boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
Posted on May 27, 2009
  • 186 Answers
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Posted on Jun 23, 2009
OXOOOOOOA5 (OXOOO1OOOA OXOOOOOOOO,OXOOOOOOOO,OXOOOOOOOO)
This looks like the codes from a Blue Screen Of Death (BSOD). If so you will need a system disk to boot from and get to a dos command prompt (black screen with white writing) and type the following command:
chkdsk /r
Check Disk Repair will run for well over an hour and you will see the percentage of completion going from high to low but that is normal. Let it run to completion and then reboot.
In Windows XP to get to the dos command prompt boot from the system disk and when the options come up select Repair. Select 1 for the Windows Operating System and when it asks for the Administrator Password just press enter.
In Windows Vista to get to the dos command prompt boot from the system disk and when the options screen open you could try a startup repair. If it fails look the dos command at the bottom of the Recovery Console.
Mar 23, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear: A problem has been detected and windows has been shut down to prevent damage to your...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Jun 03, 2011 | Computers & Internet
Windows vista on my laptop did not boot that happend when i was made some windows updates so i try to set up another windows xp from a new bootable cd ,the windows begain to set up but its shut down and a...
I had a similar problem but I can't recall if it was the same error number as in your message---what I did was used the recovery console and re-wrote my master boot record (MBR) my error was in the MBR causing my computer not to boot up in the first place. Your bootable cd should give you an option to use the recovery console before you reinstall, take it and use "fixmbr" at your dos prompt. XP works like that, but I've never had that problem with vista yet....it's worth a try if vista does the same.
Feb 14, 2011 | Computers & Internet
I have a emachine t3516 that when you boot it up, ( no matter if your in safe mode or not) the screen turns blue and these words are across the screen. ***stop:oxoooooo5o (oxooooo1oo3, oxooooooo3 ,...
Try reinstalling your windows. If you get an error on install the problem is probably in your hard drive, in which case you'll have to replace your hard drive and reinstall your windows. I really don't think it's a hard drive issue though. Sounds more like a registry issue but the easiest fix is to reinstall windows. Good Luck.
Dec 28, 2010 | Computers & Internet
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Sep 27, 2010 | Microsoft Windows XP Home Edition
Blue scree, or system crash
This link should help you a lot. The problem is an unmountable boot volume.
http://www.techtips4u.com/kb/sw/SW00014.htm
Please let me know if this helps you out.
Mar 12, 2009 | Dell Latitude D600 Notebook
Computer will not load windows
The message 'Diskette drive 0 seek failure.' is saying that there is any error trying to read 'drive 0'. As you can see from the list, drive 0 is 'ST3250820AS . 3 . ANG'. That is your hard drive that stores all of your information. Your other drive that's coming up is 'drive 1' or 'SATA 1' and that is your DVD/CD-RW. So basically your hard drive can't be read and therefore the PC can't be started. If there is data that you need on the PC I would advise contacting either a local PC shop to try and get your data recovered and put onto a new hard drive if they find that the drive is faulty. If you don't have any data on there that is essential, try reinstalling the operating system by starting up the PC with your recovery disk or operating system disk and following the directions. Make sure you read the instructions properly to insure that you install properly.
Nov 19, 2008 | Computers & Internet
your problem may be due to so many reason you have to check your ram the check your hard drive then you disconnect your optical drive, you have to do it one after one and see which is giving problem, if still you have problem plz post for futher assistance.
May 20, 2008 | Sony Computers & Internet
Computers & Internet Logo
14 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
