Question about JVC GR-D240 Mini DV Digital Camcorder
Connect JVC GR-D240ek to vista laptop
I have a JVC GR-D240ek camcorder and I want to connect it to my laptop (vista) and edit my movies that way, I have a firewire going from my camera to a USB port on laptop but am stuck from there can anyone help please?
  • samadamadog Jun 24, 2009
    I am so sorry the model of my camcorder is a JVC GR-D290 and also my laptop does not seem to have the port you are suggesting (IEEE) I can only fin USB ports a HDMI and 2 others that I am not sure what they are one has a picture next to it that is a line with 3marks underneath and 2 on top it if that helps and the other is for the ethernet cable, please say you have an answer for me!!!
    Thank you very much for helping, Sam.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Posted on Jun 23, 2009
  • Louie  Role
    Louie Role Jun 24, 2009
    Appreciate your postback and additional information.
    The same would also hold true for a JVC GR-D290. If the laptop has no built-in firewire port, then one can be installed as an add-on through a PCMCIA to firewire adapter similar to what is shown below.
    Pls click here for more details. The are other designs / versions / models readily available. The one shown here comes in a bundle with the video editing software and cable.
SOURCE:
WHERE CAN I DOWNLOAD JVC GR-DV700EK DRIVERS?
Drivers are not usually needed. Connect the camcorder to your PC with a firewire lead (preferred) or possibly a usb lead ( some camcorders only transfer still images via usb). Fire up your video editing software to capture the video from the camcorder to the PC.
Sep 30, 2012 | JVC GR-DV700 Mini DV Digital Camcorder
Hi, I have a JVC GR-D750AA digital video camera. I do not know how to download the things recorded to my PC. I have also bought the USB cable n tried but the camera USB port is not recogned by the PC. I do...
Turn the power switch on your camcorder to "Off." Connect the USB cable that came with the camcorder to the USB port on the camcorder. If you are using the DV cable, connect one end of the cable to the computer first. Put the other end of the USB cable into the USB port on your computer. If you are using the DV cable, connect it to the camcorder. Power on your camcorder. Wait while your computer recognizes the attached JVC GR-D270U camcorder. Typically you will get a pop-up on your screen asking how you want to proceed once the camcorder has been recognized. Open your video editing software, such as Adobe Premiere, Roxie, iMovie or Windows Movie Maker. Import, or capture, the video from the camcorder to your computer using the video editing software. For example, in iMovie you click on "File," then "Import from Camera" to download the movie from your camcorder to the computer.
Jan 13, 2018 | JVC GR-D275 Mini DV Digital Camcorder
I HAVE JVC GR-DX307 AS - how to save the video on my laptop or how to save it on dvd
To save the video on a computer, a firewire connections must first be established from the JVC GR-DX307 AS to the appropriate firewire port of the laptop (assuming it has one or through a PCMCIA firewire adapter card if required). In the camera, the FireWire/DV port is located beneath the mode dial on the left side of the JVC GR-DX307’s body. To access the FireWire/DV port, the LCD monitor must be first opened.
Soon as that connection is established, you can use Windows Import Video (Vista) to capture / download the videos.
Alternately, the A / V port of the camera maybe used to connect to a DVD Recorder for direct, realtime copying & burning. For the disc to be playable in another machine, it must be finalized.
Good luck and thank yu for using FixYa.
Jun 24, 2009 | JVC GR-D370 Mini DV Digital Camcorder
I am having the same problem PLEASE help!!!
ditch the usb cable and use the firewire. If Vista correctly detects AVC-compliant devices (pretty much EVERY firewire-equipped camcorder on the market!) it should "just work"
Jun 16, 2009 | JVC GR-D290 Mini DV Digital Camcorder
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
I need to have copmuter card that is to down laod from JVC DVC GR- D750AS. and what is the name of the card.
If this is a MiniDV camcorder (record to miniature digital tape) then you will need a firewire card.
Use these links as references:
For a desktop
For a laptop w/ PCMCIA
For a laptop w/ ExpressCard
You will also need a firewire cable to connect your camera to the card. If you dont have one search for a firewire 4pin to 6pin cable... such as....
this one
You can use software such as windows movie maker on XP or Vista to import your video...
Nov 15, 2008 | JVC GR-D770 Camcorder
My computer no longer recognizes my JVC GR-D70U mini DV cam when I plug it into a usb port.
Hi, I am not sure. But I believe the camcorder has to be on when you connect to the computer. and I assume you use firewire for this particular camcorder.
I too once had this problem when I used Windows Vista. If you too use Vista, try it with Windows XP.
cheers,
Sep 19, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
How to connect my jvc mini dv camcorder to my computer without the disc
try using windows movie maker which is free and is in your menus under xp or vista-make sure you are using firewire only to download video-not usb-need lots of ram to work w/video!
May 21, 2008 | JVC Cybercam GR-DV500US Mini DV Digital...
Not working in windows vista
jvc GR-DX77AS is not working when connected to a laptop with windows vista. Is there is any solution for this
Apr 15, 2008 | JVC Handycam GR-DX77 Mini DV Digital...
JVC GR-D240 Mini DV Digital Camcorder Logo
557 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
