Question about LG WM-2277HW Front Load Washer
Error code se
I have an Lg washing machine that keeps stopping at different times during wash. It shows the error code "SE", but LG state this code does not exist.
Can you help
  • 111 Answers
Can you check the temperature sensor , i know thats not the same fault , the fault to the sensor is be but check the sensor , at the bottom of the tub between the heather connections
Posted on Jun 18, 2009
Hello i have LG washer 7 kg when the motor work a few minute the display show SE if i press switch start his continue normal and repeat this state after any time
@Mowafak
"LG 7Kg SE error...."
Hello M,
The error is 5E not SE.
They look the same on a digital display :)
This is a "Water not draining out" problem.
The machine detects level of water while draining.
If this does not drain in a 15 minute time-out, error 5 "5E" pops up on the digital time display.
Somewhere in the draining path, there is blockage.
Try this:
Check your drain hose for blockages, and that it is installed the correct way.
Remove the drain hose - prepare for a possible flood from the machine drain if you do this!
Use a garden hosepipe or strong pressure tap to flush hose forward and reverse until water runs clear.
If you live in a very cold climate maybe the hose is iced up inside.
Also check all filters to see they are not blocked up.
Hope this helps,
Clive.
Oct 18, 2017 | LG Washing Machines
I need a troubleshooting manual for an LG intellowasher 7kg wd-1274FHB which is displaying an SE error code.
LG error code SE LG washing machines displaying error code SE are indicating a "motor fault" although the technical information also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and not too helpful, especially for a DIY repairer so you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you interpret that as buying and fitting a new motor, they are very expensive. You need to at least know how to test a motor for faults and check its connections and carbon brushes (if fitted) if you want to try and diagnose the cause
Nov 23, 2016 | LG Washing Machines
SE is appearing on the screen of LG washing machine
LG washing machine error code SE indicates a "motor fault" although the error code also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you are a DIYer unless you at least know how to test a motor for faults and check its connections and carbon brushes (if fitted).
Aug 29, 2011 | LG WD-80130F 7.2kg Washing machine
My washer wont rinse or spin SE keeps coming on
Hello
LG washing machine error code SE indicates a "motor fault.
You can try resetting it by unpluging the unit for 3 min and see if it clears.
If not, it s going to need service.
Apr 08, 2011 | LG WM-12230FB Front Load Washer
The display is showing se during the spin cyccle???
Hello there and than you for choosing fixya
LG error code SE LG washing machine error code SE indicates a "motor fault" although the code also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you are a DIYer unless you at least know how to test a motor for faults and check its connections.
Jan 25, 2011 | LG Washing Machines
Error code SE or 5E
'SE' is a temporary sensor error. Switch off power at wall plug, wait a few seconds, switch it back on and it may clear the fault.
Mar 28, 2010 | LG Washing Machines
LG WD-14401TB SE error code
the motor position sensor or the hall sensor part number is
6501KW2002A
May 05, 2017 | LG Washing Machines
Error "SE" on LG WD-14381FBB
That is a system error code. Try to unplug the machine for 20 minutes to reset the program module.
Jul 31, 2009 | LG WM-2277HW Front Load Washer
Error code SE on LG washing machine means what?
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Oct 19, 2008 | Washing Machines
LG Washing machine - Front Loader
Suggestion: Check your outlet filter, it could be blocked. I looked for this SE could not find it.
Jan 15, 2007 | LG WM1812C Front Load Washer
LG WM-2277HW Front Load Washer Logo
557 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
