Question about Konica Minolta Office Equipment & Supplies
What does malfunction c-3851 mean and how do i fix it.
  • Konica Minolta Master
  • 6,161 Answers
Depends on the model ????????????????????????
Posted on Dec 30, 2015
3 Suggested Answers
  • 214 Answers
SOURCE: Malfunction Detected C-3851
C3851: Abnormal Low Temp. (Heater)
Restart, holding utility key down and do troble reset, if everything is ok, the machine will work again, if not, call for service
Posted on Dec 31, 2007
sir fixalot
  • 146 Answers
SOURCE: Malfunction C 3851
C3851 Abnormal Low Temp. (Heater):
• The temperature of the Heating Roller Thermistor/ 1 (TH1) is lower than a given level of degree for 1 second or more uninterruptedly during
Ready mode, Low Power mode or printing.
• The temperature of the Heating Roller Thermistor/ 2 (TH3) is lower than a given level of degree for 1 second or more uninterruptedly during
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Posted on Jan 04, 2008
Error code 3851
http://www.fixya.com/support/t24839625-error_code_5351
Jan 30, 2015 | Konica Minolta bizhub C250 All-In-One...
P0601, and p0622
P0622 is "Generator field 'F' control circuit malfunction"- your alternator has a circuit malfunction in the voltage regulator function. You need to have the charging system checked. It may be a wiring problem in the circuit to the alternator. A shop needs to test it out.
P0601 is "Internal control module memory check sum error"- I have no idea what that means, but is probably set because the charging system has a malfunction, and the result may be memory loss in the control module when the alternator acts up. Have the 0622 fixed, erase the codes, and see if the 0601 returns. That is what I would do, anyway.
Apr 28, 2013 | 2001 Dodge Dakota
Makita hr 3851 loud noise
Take it to a service centre it could be expensive.
Apr 22, 2013 | Makita HR3851 Electric Rotary Hammer
Wiring diagram 8330-3851
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Jan 23, 2013 | Coleman Shroud Rv Rooftop Rvp Mach 3 Air...
Heng Long,Model 3851-2
Really do you think that this is one answer?
Really are you an Expert? All users deserve respect, do not need their taunts.
Aug 06, 2012 | HL 1/10 4wd Electric Speedy Mad Truck...
Security code locked
codigo de desbloqueo radio a 3851 audiobahn
Oct 11, 2011 | AudioBahn A3851 Car DVD Player
I want the instruction manual for an ACER Iconia Tab A500.
Please follow the link given below you will find the manual page http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=3851
Jul 17, 2011 | Computers & Internet
Dec 18, 2007 | Konica Minolta bizhub C250 All-In-One...
Malfunction C 3851
4 Change PWB-M
5 Change PU1
Dec 17, 2007 | Konica Minolta bizhub C250 All-In-One...
20 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
