Question about Saeco Syntia Espresso Machine & Coffee Maker
Drip tray stuck - Saeco Syntia Espresso Machine & Coffee Maker
I have the Miele 4066. I ran the descaling program. When it was finished it read a message that it didn't run properly to run again. But it gets stuck on empty drip tray mode. I even unplugged it
Take out drip tray and inspect the 2 contacts at the rear. Clean these and surrounding area. Also inspect the contacts at the back of the tray slot to see if these are also dirty. Then re-try. Hopefully this will fix the problem. Regards
Apr 20, 2017 | Miele Coffee Makers & Espresso Machines
Saeco energica is half way through descaling cycle but is getting stuck how do I reset
Thoroughly clean the drip tray before putting it back may help. If there is still coffee inside which is wet the sensor may see this as water which is still in the drip tray.
Feb 15, 2015 | Saeco Coffee Makers & Espresso Machines
The diffuser on my 4200 has stuck in a position where I can't get the drip tray in ...... Help!!!
Wash it in hot water or stick it boiling water to release the drip tray .
Do not force , or it will break .
Oct 26, 2013 | Coffee Makers & Espresso Machines
I have a Jura impressa C5, and drip tray will not go back in with the grounds basket installed. Seems as thought the mechanism is jammed out of place. I have cleaned out the tray and vacuum cleaned the...
I have a Jura Impressa 27. The tray, for some odd reason, was not going back in. I simply tried it without the top part - that receives the grounds - and was finally able to get it in. I pulled it back out and found some grounds that had been dumped. It seems something was stuck that wouldn't allow it back in with the top part. Then after I was able to put both pieces back in without a problem.
Mar 26, 2011 | Jura Capresso IMPRESSA F60
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Drip Drawer will not release
The tray appears to have been inserted just slightly askew, causing the notch in the back of the tray to get hooked under that black bit. I was finally able to remove it by tilting the front upward and pulling out. I have reinserted the tray several times since and it pulled out as simply and smoothly as it usually does.
Feb 18, 2009 | Saeco Royal Digital Plus Coffee...
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Drip Tray and Container for coffee stuck
the only thing would our drip tray is not properlt install and is jamming the rest try to move in and out the drip tray i am sure you already try it but it about the only thing that can hold the rest take our time dont force it good luck cheers
Jan 20, 2008 | Saeco Royal Exclusive 30153 Espresso...
Saeco Syntia Espresso Machine & Coffee Maker Logo
12 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
