Question about Refrigerators
TEDCO RV FRIDGE ....Is there a trick to light it on gas ,,,works on electric but cant get the pilot light to flash
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Posted on Jan 09, 2009
  • 93 Answers
SOURCE: I have a Dometic fridge with cooling issues.
theese wire that goes to the fins are your thermostat probes it possible that your thermostat is defective if you take your thermostat and bypass the two wire connected to it toghether if your fridge works replace the thermostat thanks from gilles
Posted on Mar 15, 2009
SOURCE: dometic rm2852 does not run on gas
So, the solution was simple but not obvious: the heat probe and the igniter are one and the same item, and all we had to do was bend the probe/igniter closer to the burner. After we did that the refrigerator started to behave properly.
Oddly enough, the repair manual for the refrigerator shows a igniter with a heat probe above it: the is not how the refrigerator is built.
Posted on Mar 24, 2009
VtToolMan
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
  • 46 Answers
SOURCE: royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Posted on Aug 01, 2009
WHY DOES THE FRIDGE FLASH AND BEEP BUT DOES NOT TURN ON?
It is probably activated by propane. Most fridge units on traitors are ran by propane. Set your pilot light. The casing unit should be located under the fridge area possibly in a cupboard. It also could be a electrical wiring problem.
Sep 17, 2014 | Refrigerators
I have a tedco gas electric fridge. Works fine on gas but when i switch over to electric-no go. It says it is a 12Volt 12 Amp system and has a standard plug at the rear which I plug into an electical...
there should be a small black box transformer wired into the ac cord
that goes to your standard plug
the transformer should then have wires going to your heating element
If someone has removed the transformer just order a 110vac to 12v 12 amp transformer and wire it in like you would a doorbell
when the transformer is working you should feel heat at the rear of your refrigerator at the heating element
Nov 20, 2013 | RVs
I hooked up to the electric at an RV park. After
Hi; How old is the gas operated fridge. Sometimes rust can obstruct the flow of LP through the pilot orafice. Some times by gently tapping on the pilot assembly the rust will dislodge itself. Also do You have LP in tank.
Let me know...alpharome416
Feb 23, 2010 | Refrigerators
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
Dometic rv fridge runs fine on elec, lights on gas but in one min shuts down. Dometic RV S1621 fridge runs fine with elec, when start gas operation. The burner runs for about 30 seconds then shuts off....
May 03, 2009 | Dometic RM2193 Compact Refrigerator With...
How to light the pilot in my RV?
push in on the themostat when the oven is on piolt hold a lighter under the burner and presto also light the stove to get gas flowing first this can take up to fifteen min to light if it has been awile since lit
Jul 19, 2008 | Magic Chef 9512 Electric Single Oven
Magic chef gas/electric rv fridge freezer gets cold but fridge dosn't
Jul 15, 2008 | Magic Chef Refrigerators
Morphy Richards Astral RV fridge
The Guest Post of May '09 is very accurate. I have a problem with the glow igniter associated with the black button. I need a new igniter and wonder if anyone knows where I can get parts. My model is a 7307 Morphy Richards Astral Frig.
Mel Mashman
mel@mashman.com
Oct 13, 2007 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
