Question about Winix FresHome Model P150 True HEPA Air Cleaner with PlasmaWave
Winix P150 stopped turning on - Winix FresHome Model P150 True HEPA Air Cleaner with PlasmaWave
Noisy when opporating
depends on what is cause of noise, if a fan, something in it, or could be a bearing worn
Aug 08, 2014 | Winix 50 Pint Dehumidifier WDH851
Winix wdh851 service manual
The owner's manual is here: http://www.sylvane.com/media/documents/products/winix-wdh851-dehumidifier-owners-manual.pdf
but that's probably not what you want. You might try posting your specific issue that you need the service manual for. For instance a fan that won't start is a common problem for dehumidifiers and a cheap fix. If that is your issue read this: http://www.fixya.com/support/t3588983-lg_lhd65ebl_serial_603taac20984
The article is for an LG dehumidifier but the thermistor mentioned is common to most brands.
Jul 13, 2014 | Winix 50 Pint Dehumidifier WDH851
Float Switch
Contact there customer service at: www.sylvane.com 1-800-934-9194. you will need model number etc.
Feb 18, 2014 | Winix WDH751 Dehumidifier
Turns on but fan and compresser does not run
start relay on compressor fans will not work if pumps not running
Nov 16, 2013 | Winix WDH751 Dehumidifier
Manual winix p150
Hello, this is Ava with Think Crucial.
You may refer to this online manual for your model number to help you put back the filters in your unit.
Winix WAC P150 Owner Manual
You can purchase a wide variety of high quality Winix replacement parts for your Winix Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=winix
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 16, 2013 | Winix FresHome Model P150 True HEPA Air...
How to make home airferesh
Look on the internet for making home made remedys and that should bring you to a sight .
Jan 02, 2013 | Winix Dehumidifiers
When I turn on dehumidifier I can hear the fan and compressor running but there is no collection of water in my pan
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 06, 2011 | Winix WDH751 Dehumidifier
Can I have a DH649 recharged?
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Aug 24, 2010 | Winix Dehumidifiers
The dehumidifier's fan does not turn and makes a humming noise
first,make sure the fan blade hasn't gotten stuck on the shroud and cannot turn,then shut off machine and by-hand rotate fan and see if it spins to a stop after several rotations,if it stops quickly there is a bearing problem with the motor,this is normal after many years of service,then replace the motor
Jan 26, 2010 | Dehumidifiers
Winix FresHome Model P150 True HEPA Air Cleaner with PlasmaWave Logo
Top Winix Dehumidifiers Experts
Gil Shultz
Ken Wieczorek
Ken Wieczorek
Think Crucial
Think Crucial
Are you a Winix Dehumidifier Expert? Answer questions, earn points and help others
