Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
Frigidaire DW GLD4355RF50 - display "frozen" reads washing drying and err S.. Tried unplugging, etc. holding cancel button,
kakee
  • 1269 Answers
SOURCE: Same problem. Dishwasher won't start and wash light blinks.
If the wash light is blinking, there's an internal component problem there. Mainly the fuse is blown if it's blinking. Try to unplug the power of the unit overnight to reset it. If the same problem occurs, better have it repaired. If you can manually check the back panel of your machine to see if there's an open or shorted wire there, resoldering them could possibly fix it. The last resort is to contact a repairman to replace the burned internal electronic component.
Posted on Jun 30, 2009
Waxinman
  • 56 Answers
SOURCE: Display shows PF
This is an indication that the power to the unit has been interrupted (Power Failure)
Posted on Mar 03, 2010
rylee_smith
  • 8619 Answers
SOURCE: My frigidaire dishwahser was set
Hi
Thanks for using FixYa. To resolve this press and hold the AIR DRY or RINSE ONLY button for 15-20 seconds. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
SOURCE: FDB4315LFC3 purchased in Mar 09 with error msg:
Did you ever find out what was wrong?
Posted on Oct 11, 2010
SOURCE: My frigidaire dishwahser was set to run a normal
DId you get a solution for this? Mine is doing the same thing...
Posted on Dec 20, 2010
It washes then it stops, then it read err
The control board has detected an error. Press any button to wake the machine then wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously then the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters as long as the buttons are held. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the code for further assistance.
Dec 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer model44082 will not work. It flashed err and LOC. I have unplugged and tried to cancel.it still flashes err and then LOC.
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore HE2 Plus Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Affinity washer displays ERR. PAU and 56
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Dec 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Error message wont go away
unplug machine from mains for 5 mins then try it. close IRE
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Feb 07, 2007 | Frigidaire GLTF1240A Front Load Washer
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
67 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
