Question about Wharfedale Valdus 400 Speaker
How to remove tweeter
Do I need a special tool to remove the tweeter from the unit. there is deep set sockets with some type of fixing
How to change the oil pressure on 96 ford taurus
The switch is standard pipe threads with some threadlock on it.
You can buy a special socket when you buy the switch which makes it easier to R&R, or you can use a deep socket that fits the switch.
Mar 04, 2014 | 1996 Ford Taurus
Special tools needed to replace a 2008 Honda Civic EX starter in addition to sockets, ratchet, screw driver? EX: swivel ratchet etc...
pull the neg. battery lug first.
the Plus battery lug rules are
last off , first on, or boom. acid burns. or worse. (seen many times)
you can look at it, its obvious on any car what you need.
or if really tool-less?
Read the FSM for every single step.
in my shop , i have 2 sets of metric spanners.
and 3/8 and 1./2" drive socket sets and one in deep wall.
so can do all jobs.
i cant imagine, just buying 1 socket and 1 wrench from Sears to do it. not at all, buy a set. and next time be ready.
when young, id be working to 2am fixing a car, no stores open ,with 1 DD , daily driver.
and point, 2, what if you have big arms and can grab it good.
you remove other parts to access it., and guess what, more tools,
for most cars its 2 wire lugs (nuts) spanner
and 2 wrenches on the flange nuts. 1 wrench and 1 1/2 drive.
Sep 28, 2013 | 2008 Honda Civic
What tools are required to change oil sending unit?
A deep well socket or the special socket made to fit the sending unit.
You can get either one when you buy the sending unit at the parts store.
Jan 12, 2013 | 1997 Buick Regal
Do i need a special tool to remove the spark plug as i cant seem to get a spanner on it ...aprilia mojito
HI, YOU SHOULD HAVE THE REQUIRED TOOL WITHIN THE BIKES TOOLKIT HOWEVER A SPARK PLUG SPANNER IS THE REQUIRED TOOL, DEEP SOCKET 23MM,
Jan 09, 2011 | 2004 Aprilia Mojito Custom 150
Hi, What type of tool do you use to remove spark plug from this weed eater? Is there a special tool?
Yes there is a socket that is made for that. There are 2 or 3 different sizes depending on brand name of spark plug. You can also use an ordinary deep socket without any problem. Hope this helps you out. Best regards.
Dec 30, 2010 | Garden
Fuel pump replacement, location and tools needed please
the fuel pump is located inside the fuel tank, the fuel tank must be removed to replace it, u will need a good hydraulic floor jack and safety stands to support the car, no special tools are required except the jack, just a really good set of hand tools, 3/8" ratchet and sockets, both deep sockets and shallow, metric and SAE.
Jul 02, 2010 | 1997 Oldsmobile Aurora
Does it require a special socket to remove RF and LR plugs VT750C
make sure you use either a factory spark plug removal tool or a thin walled socket. if you don't have a thin walled socket you can make one by putting one against the bench grinder.
Jan 05, 2010 | 2005 Honda VT 1100 C2 Shadow Sabre
Changing valve stem seals in a 86 saab with 2.0 turbo for an engine. Need to now what special tools if any to replace the seals
There are special tools for replacing the seals but they are not necessary. You need a special valve spring compressor for removing the springs, there are several types that should work. The types will differ depending on of it is on or off the vehicle.
Sep 17, 2009 | 1986 Saab 900
Is there a special tool required to remove the oil pressuer switc
yes and any part store will get you the socket that you need to r&r .
Jun 04, 2009 | 2002 Pontiac Sunfire
Chaning spark plugs 02 expedition
no special tools,this is what tools you will need:.7mm socket for the coil packs where underneath them is a deep hole and down there is the plugs---8mm socket for the fuel rail bolts(for the left side sitting in it)which i would use 1/4 inch drive for these--- 5/8 plug socket---6 inch extension---3 inch extension---ratchet---swivel---which i would use 3/8 inch drive for these---and maybe long needle-nose pliers incase the rubber boot from the coil packs come off and sticks to the plug.
Jun 03, 2009 | 2002 Ford Expedition
Wharfedale Valdus 400 Speaker Logo
47 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
