Question about Rug Doctor Vacuums
Rug doctor brush not moving - Rug Doctor Vacuums
2 Suggested Answers
SOURCE: rug and floor nozzle brush not moving
What I had to do was take apart the vacuum head...which is very confusing, and the manual doesn't tell you how...the "secret" is to use a flat screwdriver to pop out the little wheels...there are two other screws "hidden" beneath them. Be careful as this exposes all the electrical parts as well - make sure you're unplugged! : )
Posted on Jan 04, 2009
Rug doctor brush not moving, everything works but the brush.
There is a belt that drives the brush that may be broken or loose. If that is not it you may have stripped a gear, they are all plastic, if so you may have to take it to a repair shop.
Oct 28, 2016 | Vacuums
The Rug Doctor stopped spraying.
did you run out of water ???
Sep 30, 2015 | Vacuums
My machine trips the electricity switch in the house when I use the carpet brush tool, this usually happens after about 20minutes or so. Do I need a new brush motor or would water be getting into the...
You probably just have a circuit breaker that's become weak or is overloaded running other things as well as your machine. Have you tried an outlet powered by a different breaker? Also, if you're using an extension cord it will raise the resistance and the current draw.
Mar 30, 2015 | Rug Doctor Mighty Pro
I have a rug doctor carpet pro its red. Brushes will turn, hand tool will work but when on carpet won't spray water
Take it to your local vac shop for diagnosis. Sounds like a bad pump, or possibly a bad pump switch. It could also be a stuck diverter valve
Feb 19, 2015 | Carpet Pro Vacuums
Rug doctor repair manual
<Consumer.Support@rugdoctor.com> said: "Thank you for your inquiry about a schematic for the Mighty Pro machine. The only place that can be acquired is through Rug Doctor's manufacturing facility. You can contact our manufacturing facility at 800-964-4362 and ask for Parts. They will be able to provide you with what you are requesting."
Rug Doctor Consumer Support
Rug Doctor, LLC ' 4701 Old Shepard Place ' Plano, TX 75093
http://www.rugdoctor.com
Sep 07, 2013 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Find water pump rug doctor
is it your own machine or a hire machine?
Your best bet would be your nearest rug doctor distributor or try ebay.
Tony from DirtMaster
Feb 25, 2013 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
BRUSH NOT WORKING ON RUG DOCTOR MIGHTY PRO
watch this help video there are on you tube!
Sep 25, 2012 | Rug Doctor Vacuums
Eureka the boss the brush wont go around
Hey there scrappy13, I would suggest you unplug the unit, turn it upside down and remove the bottom plate uncovering the brush assembly. Inside there should be a belt which drives the spinner brush. If that is in tact, then the brush itself may have been unseated when you pulled the rug out. It should be obvious to find the correct placement. Reseat, ensuring the belt is attached properly to the motor as well as the brush. If the belt has broken, a replacement is available at a registered repair facility. Good Luck!
Jan 29, 2008 | Vacuums
Vacuums Logo
42 people viewed this question
Top Rug Doctor Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rug Doctor Vacuum Expert? Answer questions, earn points and help others
