Question about Dishwashers
My dsfn 1530w dishwasher is only doing a pre wash the lights that were visable showing which program it was on not longer has lights I have tried to press the program buttons then re start the machine to see if program has changed but it hasn't I have also followed the reset advise but due to the only lights working it didn't help husband thinks it might be pcb board please any advice will be much appreciated
2 Suggested Answers
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Posted on Apr 17, 2008
The start/pause button on my Beko dishwasher DSFN 6831 W is stuck in on position. Lights are on but machine does not start.
I think you have a control board fault, this is the part that is connected to and part of the buttons.
Mar 23, 2017 | Beko Washing Machines
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
Intake/drain light on
Please check the INLET water pressure, remove the inlet and check. Now if there is pressure make sure that when the power is pressed there is a pre wash cycle to start the machine. If not there is fault in the program controller , please check the door switch and the panel board.
Jan 02, 2013 | Miele Optima G2470SCVi Built-in Dishwasher
Bosch Classix SGS43C12 dishwasher programs not working & dispenser drawer not opening
The control board on this model is know to have issues with dry solder joints, If you are handy with a soldering iron you can fix it quite easily.
Mar 04, 2012 | Bosch 24 in. SGS43C12 Classixx...
My dishwasher get stuck after the pre rinse with both lights ,the pre rinse and wash lights flashing,failing to go to the wash programe.
It is likely the drain pump or hose is blocked.
It might be helpful if you can provide the full model number of the candy dishwasher.
Dec 12, 2010 | Candy Dishwashers
Hi, we have a Hoover HEDS668-80 dishwasher at work. The first problem we had was none of the programs would run this turned out to be a broken door lock. After replacement we managed to get one pre wash...
Hello... Did you check the water inlet pump is turning on to let water go inside the machine? I think if you starts a cycle and feels no water in machine it stops and give error... Hope that will be faulty or before that I'm pretty sure you forgot to open the water inlet valve because you recently repair ?? please check
Sep 21, 2017 | LG LDF6810 Built-in Dishwasher
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
testing will end shortly after water has started circulating
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Sears Dishwasher in " Lock" position
unplug the power longer, or its sounds like a wash delay setting is programmed
Feb 11, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Hi All, we have just bought and fitted a Hoover HEDS 668-80 Dishwasher. When we tried to run the first wash, the pre-wash and wash light both light up simultaneously. The instruction manual says this...
you do not have enough water pressure,, either change the water supply or check the pressure in your house should ba about 70lbs, to work the unit properly,, you could also increase the water supply from 3/8 to 1/2 inch up to the connection of the unit
Dec 08, 2008 | LG LDF6810 Built-in Dishwasher
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
