My LITEON 5045GDL+ dvd drawer wont open.
My LITEON 5045GDL+ dvd drawer wont open. When i can get it open,it then wont play the dvd.
  • 6,784 Answers
HI, you have two issue here. the load motor is malfunctioning. this is causing the door open and close feature to lock up. this motor is connected to the gear assembly. it should be replaced soon. the second issue is the optical lens assembly. this len assembly has failed. the laser is burned ut. this is causing the no play issue.
In conclusion, i recommend replacing the optical len assembly and the load motor as well. this will fix this issue. try not to force the door open often, this Will damage the loading dock gears.
Posted on Jun 18, 2009
This is a dvd recorder for a tv the door door to yhe dvd will not open
sounds like something has jammed in the drawer track
on the front of the drive is a very small hole
that is the manual open override
use a paperclip and push it into the hole as far as needed until the drawer opens
then slowly open the drawer by hand
look on both sides of the drawer to make sure there is no dirt or other foreign matter in the tracks where the drawer opens
Dec 16, 2010 | Lite On LiteOn 16X Dual Layer DVD...
Just purchased a liteon dvd burner.When I try to burn copy of dvd movie; the message I get states that the movie is copyguarded. My old dvd burner has no problem copying copyguarded movies using...
you might need a program like AnyDvd which removes copywright from a dvd and allows you to burn it without any restrictions to be able to play the dvd in australia
hope this helps
Dec 13, 2010 | Lite On LITEON 16X DVD BLACK OEM (Come...
In 2005 our historical society bought a Liteon DVD recorder LVW 5007 to made DVD's of camcorder interviews for our towns history. After making about 50 of these DVD's Our Liteon machine will not let us...
It is mechanical. You can remove the screws and remove the top case to inspect the inside. You may not be able to fix it yourself but at least you'll get a look inside.
Aug 13, 2010 | Cameras
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
It wont play any dvd disc
You should be install CyberLink PowerDVD Player and than try to play it.
Jul 23, 2009 | Lite On DVD+/-RW LITEON SOHW-1673S BGE %...
Liteon LVW-5005 DVD Recorder. Disk drive door will not open.
give it a tap on the bottom as you press the button, this will force it to release the disc,
Jul 03, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Jan 27, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Playing disc
any disc recorded on the liteon must be "FINALISED" before it will play on other machines.use "disctools" in the liteon menu to tdo this.
Sep 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
