Question about Riso Office Equipment & Supplies
MASTER ROLL JAM EZ220-U - Riso Office Equipment & Supplies
How can the master roll be opened without the use of the release button?
by using & insert a pencil or 4mm screw driver , press manually master unit release switch on master unit cover ( small hole ) on bottom side of master unit cover and draw master unit by other hand
Mar 02, 2015 | Riso RZ220 MASTER UNIT - ONE ROLL PACK
Master roll rz
yes but it is always good to use original consumables. plus if your unit is under warranty, you can ask for help with the company anytime.
Jan 22, 2014 | Riso RZ220 Duplicator
1997 jetta window won't roll up
oftan times its the master controle switch on the driver side that allows the power for the passanger sid the other comman problem is the harnes in the door jam has a broken wire or more than one take the pannel off the kick pannle off unplug the harness at the kick pannel take the rubber loom cover between the door and the rig loose pull some wire through so you can see it and find the break and repair hoped this helped
Jul 22, 2012 | 1997 Volkswagen Jetta
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    I have the d17 error message. I did try to reset it but it still shows the error.
    D17
    236 - incorect master roll
    237 - master roll undetected
    238 - master roll communication error
    239 - wrong master roll detect
    241 - detected a mismatch in master roll information
    you must stop the machine and remove the cable from the print drum PCB and check that there is no ink on the connector or the PCB.
    If there is no ink try to enter in test mode and activate 0890 test.
    If it dose not work call for tech from Riso.
    Dec 01, 2010 | Riso RZ220 Duplicator
    Code D-17-236 The Riso just stop working, Why?
    A D17 is incorrect master roll installed. This could be caused by a) it IS the incorrect master roll, or b) the RF tag that is inside the master roll has gone bad. Try a new one in the original packaging to help with diagnoses. Make sure they are RISO Z type master rolls specific for an RZ220.
    Jan 21, 2010 | Riso RZ220 Duplicator
    Showing paper jam at master disposal NOTHING THERE
    Remove the power cable from power source for few minutes. If its a temporary software issue it will get sorted out. Pull out master roll and reinsert it. Check wether you have properly inserted the master disposal tray or not. If these don't work ask for further assistance.
    Jul 17, 2009 | Riso RZ220 Duplicator
    Paper jam, paper was removed still says paper jam
    some small partical must be their on printer papper sencer ... or may be senser spring in jammed
    clean it
    Dec 02, 2008 | Office Equipment & Supplies
    Riso gr 3770
    - Please check if they have Master Roll Jam?
    - Install properly the Master Roll.
    Sep 18, 2008 | Office Equipment & Supplies
    16 people viewed this question
    Top Riso Office Equipment & Supplies Experts
    CheckitRight
    CheckitRight
    Marius Chiriac
    Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
