Question about RCA 25404RE3 Corded Phone
How do I set up my speed dials? - RCA 25404RE3 Corded Phone
Next to the screen there is a "store" button. Press the button once than dial the number you want to store. Then press the button again and choose the spot where you want to store the number. The screen should then read "ok".
Posted on Jul 07, 2009
    New Friend:
  • 70 Answers
You can go to settings or contact su will find an option speed dial then set the numbers u want.
Posted on Jun 18, 2009
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
Aug 18, 2011 | Uniden Cell Phones
We have a new wx345 cell phone that we have set up with speed dial numbers but I do not know the procedure used to call or dial any of the speed dial numbers. Can you help us use our speed dial?
If you have set up your numbers with speed dial, make sure the speed dial option is set "ON". When you are ready to make a call, press and HOLD the speed dial number you are calling. I had the same problem and found the solution on another online forum.
May 20, 2011 | Cell Phones
How do i set s speed dial
just go to speed dial option in your cordless and enter the numbers you want on speed dial or directly you can contact with each other through cardless and no need of speed dial it can be done when you have two hand sets directly link with each other
Jun 03, 2010 | Uniden 5.8GHz Cordless Phone
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Sep 11, 2009 | HP Office Equipment & Supplies
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
Jul 29, 2009 | Dual Electronics CECT P168 Cellular Phone
Can't delete wrong speed dials set up by my wife
You should be able to reassign the speed dials if you want to by going to settings/ speed dials.
Jun 01, 2009 | Nokia 1100
Program and use speed dial numbers
speed dial must set at port ' 00 ' or 000
to check, use display phone, press #402 or #401
speed dial code are from 60 to 99
to set press speed dial , redial , speed dial code eg. 60, press 9 follow by destination number asn redial to confirm
to use speed dial to call press speed dial short key follow by speed dial code or *60
May 26, 2009 | Toshiba Lands Phones
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 | Nokia 1100
How do I set up and use speed dial on a Toshiba dkt2010-sd
what system u using??
if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
- to set speed dial press REDIAL SPEED DIAL standard speed dial   code 60 or 600, follow by 9+destination number, REDIAL to confirm.
- to call press speed dial + code or press * + speed dial code (*60 / *600)
- if CTX/CIX must set at adminsrater phone. #66, speed dial code number (200-999), 9 follow destination number #
- to dial press *200...
Apr 22, 2009 | Toshiba DKT2020SD Phone
How do I set up speed dial for a Toshiba DKT2010-Sd phone
what system u using??if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
RCA 25404RE3 Corded Phone Logo
126 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
