Question about KitchenAid Dishwashers
Wiil not drain
Water standing in tub. restarted and not soung made. lights come on but does not run. has not had any previous problems. MDL. KUDS24SEBS3
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Pump must be frozen. It should be directly under the machine, try to turn it with pliers.
Posted on Apr 15, 2014
ginko
  • 19396 Answers
SOURCE: Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
Posted on May 21, 2009
  • 44 Answers
SOURCE: mdb7100aww maytag, just not draining now. never
Elimination Of Problems From Most To Least Likely:
1. Connection from discharge hose to drain pipe is blocked/corroded.
a) Loosen the gear clamp (5/16" Nut Driver/Phillips/Standard) holding the discharge hose to the barbed drain fitting.
b) Check that the barbed fitting is not blocked by poking at the opening wth a screwdriver.
c) If the barbed connection is Galvanzied and it has gotten heavily corroded, replacement of that fitting is recommended.
2. Discharge hose is blocked/kinked from dishwasher to drain connection.
a) After 1b), place discharge end of hose into a bucket and run the dishwasher through a cycle.
b) If flow is poor, examine hose for kinking or parts (such as couplings) that may have corroded shut. Removing front panel and using a flashlight will be required for this (1/4" nut driver/phillips) If such corrosion found, 1c).
c) If hose and fittings are ok, there may be an inline filter whose screen is clogged or a filter screen where the dishwasher ties into it's discharge line.
3. Pump has failedinternally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears
N.B. May be under warranty - check. May be cheaper just to get another dishwasher at this point, especially if the dishwasher is more than 10 years old.
Posted on Aug 08, 2009
SOURCE: Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Posted on Aug 05, 2009
SOURCE: Draining Problems
Use about a cup of Muriatic Acid. Run it through the dishwasher ( Empty of Course) five times. Only use the acid on the first cycle.
Posted on Oct 20, 2009
  • 744 Answers
SOURCE: Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Posted on Jul 09, 2010
What does code f03 mean
An F03 error code on many front load washers indicates a failure to drain properly. You can usually clear this fault code by pressing the pause/cancel button. Next, check the drum for water. If the drum still has water in it, restart a drain and spin cycle. This should drain the water from the tub.
If your washer will not drain, check the drain hose for kinks or clogs. Make sure that the drain hose is not stuck more than 8 inches down the stand pipe.
If you do not hear your drain pump running, you may have a problem with your control or your drain pump. Also, if your pump is making a loud noise, it may be clogged. These problems would require service by a technician.
May 19, 2015 | Washing Machines
Fisher paykel GWL10 doesn't drain Previous problem
Easy to check the pump but you need to have a bucket handy. Tilt washer backward pump will be on the right side. Remove and clean. Watch out for the water!
Sep 26, 2013 | Washing Machines
Kenmore washing machine will not drain water /spin cycle
There is likely an object (like a sock) lodged in the drain hose that runs from the tub to drain pump. It could be in the hose in which case a squeeze will verify, or jambed against the drain pump impellers. It could even be between the inner basket and outer tub covering the drain hole. Regardless it is usually easily retrievable with a little ingenuity as well as a little to big mess of water. So prepare for the water if you losen a hose. Unplug the machine before you start because electricity and water are never a good combination. A wet dry vac works good to remove standing water in the tub and you can even hold the nozzle over a loosened hose to remove water from it as it pours out. Let me know if you run into difficulty.
Jan 11, 2013 | Kenmore Washing Machines
My GE Washing Machine fills up with water to the appropriate line and then begins the agitation cycle... The water immediately begins to drain to the point the water turns on to fill the tub again... this...
is the drain hose connected to a drain standpipe or laying in a utility tub , or a floor drain check owners manual for proper drain hose height and requirements if drain hose is lower than the height of washer it can auto siphon out of drain hose ,,,,, is the drain hose sitting in stand pipe freely or is it connected to stand pipe with no air gap
Jan 24, 2011 | Washing Machines
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Maytag top load washer water runs but doesn't fill.
Drain is to low. You will have to raise the drain hose above the top of the washer. Whats happening is the water is siphoning out as fast as it goes in.
Please rate this solution
Sep 02, 2009 | Washing Machines
Washer will only fill halfway
hello, 1 possable problem a pretty common problem and the solution is blindingly simple. It’s caused by the drain hose siphoning water out of the washer tub. There are two common causes for siphoning and I’ll explain both of them below.
drain-min.jpgOne cause for siphoning is simply that the drain hose discharge is below the fill level of the washer tub. This picture shows the minimum drain height needed to avoid siphoning.
Another common cause for siphoning is not having an air break between the drain hose and the drain stand pipe. Usually, this isn’t a problem since the drain hose diameter is usually much smaller than the diameter of the drain stand pipe. But sometimes folks will inadvertently remove the air break by duct taping the drain hose to the stand pipe. They might do this because the drain hose keeps popping out of the stand pipe when the washer pumps out the tub. Other times, the drain hose might fit into the stand pipe with a tight interference fit.also check your water inlet valve filter/screen make sure its not clogged.
Apr 09, 2009 | Kenmore Washing Machines
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine
the number one cause of this is your drain hose is too far down in the stand pipe or too low beneath the tub the drain hase should loop above the tub and about 4 inches down in the stand pipe if not this will create a siphoning effect that will drain the water as it fills
Jul 13, 2008 | Maytag Ensignia MAV2757AWW Top Load Washer
Non-stop draining at whatever cycle selection
Is your drain pump constantly running? If it isn't, check the standpipe (drain pipe) and make sure you don't have your drain hose shoved down in the pipe too far or the top sealed off. The stand pipe needs an air gap to properly drain, or it can siphon water from the wash tub. Symptom: Washer continually tries to fill or slow fills, but water won't stay in wash tub. Double check your drain line to be sure. It could be a simple fix.
May 16, 2007 | Kenmore 46462 Front Load Washer
Dishwashers Logo
281 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
