Question about Toaster Ovens
Electrical connection to Slimline 600S
Connecting power supply tob unit
How can I get a copy of instructions for Cuisnart convection oven TOB 165?
Cuisinart has the manual for the TOB-165 on the Product page; it's a discontinued model. See https://www.cuisinart.com/discontinued/toaster_ovens/tob-165.html . The direct link to the instruction book is https://www.cuisinart.com/share/pdf/manuals/tob-165.pdf . (Note: you will need Adobe Reader or a similar program to read or print the manual.)
I hope this helps.
Aug 09, 2015 | Toaster Ovens
Unit will not turn on. No power to anything on the display. The outlet is verified working. This happened once before and a few hours later just miracled itself back to life. any idea Is there some...
An loose, intermittent power switch is the cause of that and it associated with lose wiring inside. Check it and replace lousy parts once you done that your unit will back to normal again.
I hope my idea help you.
Apr 04, 2011 | Cuisinart TOB-155 1500 Watts Toaster Oven
Cuisinart TOB-30 toaster oven
I have the identical problem. Where can I find a replacement foot?
Mar 14, 2009 | Cuisinart TOB-30 Toaster Oven with...
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Cuisinart TOB-175
It is roughly 17 inches across from left handle to right handle, but slightly less. About 15.25 inches from front to back.
-Tha Mp3 Doctor
Dec 30, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
CUISINART TOB 175 CONVECTION OVEN MANUAL
Cuisinart has the manual on their website:
http://www.cuisinart.com/manuals/index.php?cat_id=15
Scroll down to the link for the TOB-175.
Nov 19, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Warning tone?
Have you tried turning the function button to off? This has worked for mine.
Aug 18, 2008 | Cuisinart TOB-30 Toaster Oven with...
Broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster oven just stopped working...
With mine, the toaster function stopped working. The light lit, but the relay did not click. This happened about a year ago, but then it started working again. Now that my waranty expired, it seems permanent.
The relay requires 12V, but I only measure 5V (no audible click). When I pulled the relay, the drive went up to 12V, so the coil is loading down the source. Not sure whether the problem is the coil or the source. It would be nice to find a schematic. When I put the relay across a car battery, I heard the click indicating that the relay is working.
I cleaned the contacts, and get the same result.
Jul 22, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster Ovens Logo
23 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
