Question about Dahle Office Equipment & Supplies
Jam light stays on no power - Dahle Office Equipment & Supplies
My Denon AVR-1804/884 standby light stays on but the receiver wil not power up
ok my denon avr 1804 was jamming and it shut off on standby red light flashing comes on then goes back off what is wrong ?????
Feb 27, 2011 | Audio Players & Recorders
Hp laserjet printer p2015 the jam light stays on there is no paper jam. Cannot get the green status light to come on cannot print at all
Hi, first; lets’ start from scratch. Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. Thanks paul7of9
Jan 12, 2010 | HP LaserJet P2015dn Printer
Paper jam stays on without paper jammed in machine
try this... reset the printer...
Next... reboot the computer... this should reset the printer and the computer and the system...
Oct 25, 2009 | Lexmark X4550 InkJet Printer
Paper jammed light stays on after removing jammed paper.
Make sure you have opened all doors and pulled out all paper trays. After turning the copier on and off if jam light stays lite then you will most likely have a sensor problem (fell out or broken)
Oct 18, 2009 | Canon PC-940 Black and White Copier
Power light is on, and nothing happens.
The RAM may have been "jammed up" when it was put to sleep. You said you powered down completely and then started up again. How long did you leave it before turning it back on? Try it again, but this time, unplug the adapter from it and also take out the battery so there is absolutly no power going to it. Leave it like that for about 5/10 minutes and then try it again.
Hopefully that will help you out
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Attention light blinks after jam
most of the HP printers will detect the paper jam and will provide you with help window automatically to rectify the problem. If paper gets jammed, just remove it from backside and then turn off the printer and power it on. cancel any pending printing documents. Everything have to become normal. If it not, try restarting your system too.
I hope its helpful to you
Sep 07, 2009 | HP Photosmart D5160 InkJet Printer
Brake lights stay on continuous
Sounds like you have a jammed or bad brake light switch.  It is mounted on the brake pedal.  Check to make sure it isn't jammed somehow.  If not, you probably need to replace.  Hope this helps.
May 19, 2009 | 1999 Volkswagen Jetta
Red light stays on, but nothing moving after clearing paper jam
About the last post, I must also add that the main clue that led me to that conclusion, was the fact that, when I first turned the printer on, THE FAN BEGAN to rotate. Hence, I thought, all the other aspects were right, but somewhere there might be a mechanical "jamming" that stops either the fan or other part to move and obstacles the cylinders or gears from moving, hence sending the printer a signal of jamming. I had looked for the "messages" from the printer, and the diagnosis for our problem (red light in the online error, and green light in Toner Save) was that either there was no ink or no cartridge, no paper, or paper jamming (please post if there was other cause for this diagnosis). I discarded the other grounds, so the unique left was that the printer thought was that there was a paper jamming. This lead to the fix I described in my previous post.
Regards,
David López Salgado
Bogotá, Colombia
May 02, 2009 | Samsung ML 2010 Laser Printer
Shutter stays open
Lens is jammed , needs to stripped and reset.
Apr 21, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Misfeed indicator light stays on-printer not working
When ever there is a jam be sure to try and remove the jam without tearing the paper. If you do rip the paper piece it back together to assure you removed all of the jam. If there is one tiny scrap left and it lies across a sensor the jam will remain. Easier to happen than you may think.
Senior service tech for 15yrs
Mar 17, 2008 | Sharp AL-1540CS All-In-One Laser Printer
44 people viewed this question
Top Dahle Office Equipment & Supplies Experts
jhnolson
Dennis Key
Dennis Key
Are you a Dahle Office Equipment and Supply Expert? Answer questions, earn points and help others
