Question about Cyber Acoustics A-3780 Computer Speakers
My boyfriend just passed away and had unopened speaker in his closet for years I just opened it and it doesn't have the mouse in it!
Keyboard doesn t work
test with a USB keyboard and mouse, also, its possible that the ribbons have come away, open and check there in ok.
Oct 07, 2013 | Medion Computers & Internet
We have an amana ac. It recently started making a loud noice from the furnace closet which is upstairs. 2 different ac repair companies came out but could not find anything wrong. The line to the outside...
Hello, if the line is freezing there is either a airflow problem or low refrigerant charge. If there is a loud noise most likey the bearings on the motor or the blower wheel is bad and causing a lower amount of air passing over the evaporator coil and thus the freezing of the suction line.
Jul 15, 2012 | Heating & Cooling
I was just wondering what the expiration date is on your mascara if it is unopened?
Hello Dear
Expiration date on mascara shows that it would may be get dry on this date. if you unopened the mascara for a longer time after the expiration date, you would not be able to use that. or may be it would have a bad effect on your lashes.
regards
(Please donot forget to rate)
Mar 16, 2011 | Tarte Increases Lash Volume By 424%...
My boyfriend bought a 1996 ford explorer, from a friend who is now passed away. Every now & then the alarm goes off but he does not have a remote for the alarm or the code for the keyless entry on the...
The security computer box is in the cargo area open the rear hatch on the driverside behind the plastic is the box, it will have the keyless entry code printed on the side.
Jan 18, 2011 | 1996 Ford Explorer
An odd question I know but does perfume ever go off? I opened a perfume from Christmas 2006 and was not sure if it was just a vile perfume or whether it had actually gone off?
In answer to your question, the simple answer is YES!
New unopened fragrance normally lasts at least a year or more if kept properly, but opened perfume will eventually go off as it is based on a volatile liquid that will evaporate.
The smell will definitely be a give away (but as you say, it could just be an unpleasant scent) but also check the colour to see if it has darkened significantly or thickened.
The usual advice to prevent this happening is to ensure your perfume lid is secured tightly and not placed in direct sunlight or near a heat source.
Unfortunately there is little you can do with it once it has gone off - if I were you, I'd play safe and throw it away!
Sorry I can't be more positive.
Nov 23, 2010 | Health & Beauty
FORGOTTEN PASS WORD
Upon starting this computer up keep hitting the F8 key rapidly until a repair dianogstics screen appears. Choose from the list by starting this up in the system restore mode. This will reorganize the computer as it was when first purchased without any passwords locked into place
Jul 18, 2010 | eMachines D3123 Desktop Computer With AMD...
Unopened email star is showing but have no unopened emails
try going to options > security options > firewall then hit the BlackBerry button and hit Reset All Counts. Then do a battery pull.
Come find me on twitter as @nanpalmero
Jan 21, 2009 | AT&T Blackberry Curve 8300 Smartphone
Cyber Acoustics A-3780 Computer Speakers Logo
44 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
