Question about Samsung HT-X40 System
Display PROTECTION and shurt-down - Samsung HT-X40 System
I have a coolpix L23 and she turns off for no reason, and when im trying to record when i click on the button it shurts down. have any ideas of what the problem might be?
Please make sure you have a good FRESH batteries. The batteries you are using may be old or discharged. Wen a camera behaves like this always assume power or batteries.
Feb 11, 2017 | Nikon Coolpix L23 Digital Camera - Blue...
Tip
Panasonic CT-32HL43G
Hi my name is Aleixo. I have problem with this set. When I star fix it, it had oppend the mais fuse, I replaced it and I start usin one serial boolb light to save the fuse. It has some shurt but I can't find it. I think: Flyback, Vertial IC, Video IC but like fine, I desconnected the demagnetizer coil. It istill with shurt. I don't have schematic. If someone know please I need help. Thanks
on May 09, 2008 | Panasonic CT-32HC14 32" TV
HOWTAVOIDAUTOPROTECTION
When the "Protection" indicator comes up the display panel of Denon ... In thermal cases, the circuitry will automatically reset after a few minutes of cool down
DC Protection is not something you can turn off..
Sep 04, 2015 | Denon Audio Players & Recorders
We have a 2000 Daewoo Nuberia that sometimes the electrical system shuts down engine may or may not stop running. After about 10 to 15 minutes car will run ans systems work normal again. Is there a ma
Try a check the tepreture sensor if its not working well it cause such problem . Change it if posible. That sensor can cause injector to shurt down they wont allow fuil in the engine .
Sep 23, 2014 | 2000 Daewoo Nubira
My 1995 Acura Legend has a oil light that comes of and on. I recently drove it 50 miles when off the highway the car shut down on me. But turns over when trying to restart.
When your oil light often refered to as a "dummy light" comes on you should immediatly shurt your car off and call a friend to bring you oil. If you have checked your Oil (with the car off and sitting for a few minutes) and it is all the way to the second dot on the dipstick then your oil level sensor needs to be replaced.
Jul 05, 2009 | 1995 Acura Legend
Hello Protection Samsung HT-DS900
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 14, 2009 | Samsung HT-DS400 System
Click and light on front flashes!
This showing the tv have power. Maybe when you pushed the power button it clicks and shuts down then show the red light bliking showing one code. Some shurt on horizontal board or loose some voltage from power supply. This is not easy if you don't have experience with electronic. I'm sorry still tring
Sep 07, 2007 | Sony KV-35S66 35" TV
Samsung HT-X40 System Logo
51 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
