Question about Dewalt Drills
Circuit board range - Dewalt Drills
JBP65G GE range oven won't shut off
Electric Ranges have circuit boards that control the power to each burner or element. Circuit board could be faulty. I would not mess with electricity unless you know what you are doing. Call a certified repair specialist or the manufacturer if under warranty. Good Luck
Jan 31, 2012 | GE Kitchen Ranges
Fried mother board
Hi!!
Click on the following link to identify your circuit board and order it. Price runs about $95.
http://www.repairclinic.com/Circuit-Board-Or-Timer-Parts?s=t-PLES399EC-%3d%3dc13e
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 03, 2010 | Frigidaire PLES399EC Electric Kitchen...
My oven and stove top in inoperative. the clock,
If everything checks out fine, and you have no wires grounding out, then the issue is the control or circuit board( same thing).
Jan 02, 2010 | Frigidaire FEF366 Electric Kitchen Range
My range has a F-1 code on the
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. ..
F1 Circuit board defective Replace control board
Oct 16, 2009 | Hotpoint Kitchen Ranges
Blank Display on Electronic Oven Control
If the burners are working it is not the circuit breaker as both use the same circuit. The board does use the ground or neutral wire. I would check that and see if there is 12VAC supplied to the board. If there is then it would appear you have a fried board.
Eric
Jun 27, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Braun QS3 Range Hood
The circuit board that we use to replace the old ones are a new generation of circuit boards. To this day i have never had to replace a circuit board that i had already replaced, and beleive me i replaced a fair share.
Jun 13, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
CIRCUIT BOARD
If your replacing it yourself The clock is under $100 if you have a service company replace it it may cost alot more.
May 15, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Dacor error messge
The Door lock safety circuit on power relay board sensed. Check your power relay board and door lock circuit. F9 indicates the problem is with the lock circuit. Shut the power off and see what happens if nothing then do the checks. You can have a problem with the latch assm. the lock switches the relay or even the ERC (electronic range control).
Dec 20, 2007 | Dacor Preference RSD30 Gas Kitchen Range
Fridgidaire elctric oven with the touch control pad
MOST OVENS TODAY HAVE THE CLOCK/CONTROL AS ONE UNIT THAT HAS THE RELAYS THAT TURN ON THE BAKE/BROIL CIRCUITS. SOMETIMES THE RELAYS FUSE THE INTERNAL CONTACTS KEEPING THE CIRCUIT RUNNING AFTER THE MICROCOMPUTER SHUTS DOWN THE CIRCUIT.
THE OVEN CONTROL WOULD NEED TO BE REPLACED.
IT IS ALSO KNOWN AS THE CLOCK.
OCCASIONALLY, THE MANUFACTURER WILL HAVE A SEPARATE RELAY BOARD AND CONTROL BOARD. FIND OUT WHICH CONFIGURATION YOUR RANGE IS AND REPLACE THE PART THAT CONTAINS THE RELAYS.
Dec 20, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Drills Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
