Question about Culligan Tools & Hardware - Others
Culligan ac30 constantly runs even when tank is full the auto shutoff is good along with the caparillary refill.could the manifold be bad?
SOURCE: no water from Culligan Aquaclear AC30 after replacing filters
Try reducing the pressure to 7-10 PSI empty then no more than 35 PSI when the tank is full. This should solve the problem.
Posted on Aug 20, 2009
h2oservices
  • 306 Answers
SOURCE: Culligan Gold series softnerdrain line runs constantly in street.
The main piston/sealpack is frozen up and needs to be replaced. There is a retrofit kit available from Culligan to repair this issue. The reason it stops when bypassed is the water is shutoff to unit.
RJ
Posted on May 14, 2011
h2oservices
  • 306 Answers
SOURCE: water softner problem, does not refill water to brine tank
There is .25 gpm flow restrictor in the top of the float assembly, It may have sediment in it. Unscrew the cap on float top and check the restrictor. When you hook it back up run the system to refill (last cycle) hold the float stem down until all the air is purged from float assembly and see if that works. Also the float ball (foam) may have slipped top too far and is shutting off prematurely. If this does not work it is in the valve which has small pistons, diaphrams and springs to control the cycles. Each cycle also has a solenoid which makes these components work. You will not find a service manual for the Mark 50 valves. They are obsolete unfortunately and parts are no longer available. This valve was made for nearly 40 years and was the hallmark of the Culligan line.
RJ
h2oservices
  • 306 Answers
SOURCE: It's time to replace the filters on my Culligan
I have used numerous sets of Culligan filters and membranes from this on-line supplier and had very good success with them. No issues as with other knock off filters. No I do not work for them.
http://www.uswatersystems.com/
RJ
Posted on May 19, 2011
h2oservices
  • 306 Answers
SOURCE: The housing for one of the filters on my Culligan
Culligan should have a used filter housing to replace the broken one. I think those housings have a 10 year warranty. I would check your warranty if you are the original owner.
RJ
Posted on Jun 04, 2011
Culligan AC-30 Howling Noise
yes you answered your questions there. i researched info and more than likely it is the valve
http://watersoftenernews.blogspot.com/2014/02/culligan-water-softener-noise.html
Oct 13, 2014 | Culligan RO Compatible AC30 Compatible...
6 stage ro system under counter style will not stop draining or producing ro water at all I removed unit changed 3 pre filters and a post polisher now I gotta problem How long will this unit run to fill...
If the RO is not shutting off and there is no water from tank there are several things to check.
1. The product water tank is probably low on air. The tank may be full but no water will come out. Put enough air in tank to force out all the water then reset air pre-charge to 7psi for 3 gallon tank.
2. The capillary tube / check valve of RO system is bad. This puts back pressure on membrane to help create water.
3. The Automatic shutoff is not working, causing the unit to run constantly.
I would have to know what model RO it is to narrow down the problem further.
Depending on the Membrane production 10, 25 gpd, etc. and the TDS of water it may take 24 hrs to fill the tank.
RJ
Oct 07, 2011 | Culligan Under Sink Water Filter
Culligan under counter system, ac 30, replace filters in past and tank filled up. The tank will not fill this time and the water in the flush line is running. Is the automatic shut off bad? what am I...
Make sure the line to RO tank is not pinched. The automatic shutoff may have some carbon fines in it. It can be taken apart and cleaned. Also if you are using a piercing valve to feed the RO make sure there is enough water coming from the valve. I would take the filters out again just to double check them also.
RJ
Apr 17, 2011 | Culligan Under Sink Water Filter
Our system is only running small amount of water through to the drain... system operating panel just says C5! Even after unpluging and repluging it doesn't change. Does the system need repair?
If it is running small amounts of water to the drain when it is in service position this means you have a bad seal pack and it needs to be replaced. The "sealpack" is the main piston and seals that control the hydraulics of the valve. When water runs to the drain constantly either the piston is jammed (which would show an error code) or there is a bad seal causing water to get by. I suggest calling Culligan or if you are handy you can do this yourself. You need a sealpack and refill piston. It takes about 20 minutes. The kit is available from Culligan.
RJ
Jan 30, 2011 | Culligan Sediment Water Filter
RJ
Jul 25, 2010 | Culligan Sediment Water Filter Heavy Duty
It's time to replace the filters on my Culligan AC30 Reverse osmosis system. I see major savings on the web with compatible filters vice those provided by Culligan. Any appreciable difference in...
RJ
Jul 06, 2010 | Culligan Under Sink Water Filter
Proper Disposal of a Culligan Mark 50 Water Treatment Tank?
If you disassemble the valve completely (all metal parts) the valve itself is delrin plastic and is recyclable along with the brine tank. You may be able to scrap the softener tank. You will have to get all the resin and gravel out of it. Just tip it over take the inlet manifold out and drain the resin into a bucket, take the resin to culligan for disposal.
RJ
Jan 02, 2010 | Culligan Sediment Water Filter Heavy Duty
How to sanitize ac30 culligan RO sytem?
It helps to sanitize the RO system each time you change the filters. Always test the RO water with a TDS meter to determine if the TDS rejection has dropped below 80% rejection. If it has the membrane should be changed along with the other filters. Always wear latex gloves when changing RO filters to prevent bacterial contamination. There are complete instructions on sanitizing the RO in the Culligan manual. Here is the link for the AC30 Manual.
http://www.freshwatersystems.com/support/AC-30.pdf
RJ
Dec 31, 2009 | Culligan Under Sink Water Filter
Constant flow from my culligan soft minder twin water softner
A constant drip to drain or brine refill indicates a problem with the seals in the valve. You need to determine which tank is leaking. The piston and seals need to be replaced.
RJ
Oct 02, 2009 | Culligan Sediment Water Filter
No water from Culligan Aquaclear AC30 after replacing filters
Aug 09, 2009 | Culligan Under Sink Water Filter
Tools & Hardware - Others Logo
154 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
Jim London
Jim London
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
