Digital display on the dvr has disappeared while watching DVD this caused the DVD to stop and now cannot turn on the machine turn the machine on or retrieve the DVD in the machine
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
SOURCE: Pulsar NX14 Digital Display gone blank
Do not panic yet - all you need is the battery replacement.
Don't mind that the watch is less than a year old - it may laid in sellers store for a year or so and as the watches are not refitted with the brand new battery at the selling point, they may have underpwered battery much more quicker than you expected
Find your nearest watch repair shop and ask for battery replacement. Your watch will tick as brand new and will last much longer then before.
Do not forget to rate, please.
SOURCE: unable to display battery charge on taskbar
Select power management from control panel. there u will be able to turn it on.
Cheers.
SOURCE: Digital display has disappeared on dash.Was ok
Some VFR's had a problem with the printed circuit board behind the clocks. A track or two could corrode away giving all kinds of electrical faults. If you can remove the dash unit you may be able to see any lost tracks and repair them by soldering in a bit of wire.
Testimonial: "Thanks for your reply,i took the plunge and removed the front end,got the dash off and fixed the problem.Many thanks,tim."
SOURCE: Display disappears when Indiglo is pressed
That means your watch has two batteries - one for the movement and another one for INDIGLO. It may have just one battery, but in this case INDIGLO is taking up too much power. Replace the battery and you will be sorted. Rate me, plz.
