Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Error OE LD-12BTY. stops a few minutes into the cycle with an error OE.
  • 111 Answers
Thats a drain problem , blocked drain hose , drain pump stuck or burned , last case scenario electronic control
Posted on Jun 18, 2009
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
My LG dishwasher is stopping after a few minutes into the wash cycle with an error message OE and making a sound. The dishwasher tablet is still inside the dispenser and while there is water in the unit it...
Hi rebeccasolom,
OE means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks.
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
May 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
Our dishwasher keeps stopping its cycle and saying 'OE' It is LG - LD/141ST1
the 'OE' code means clogged or kinked drain line. You will need to pull the dishwasher and disconnect the drain hose from both ends and flush out debris at the sink. Be sure the hose isn't kinked.
Sep 22, 2010 | LG Dishwashers
Instead of showinf a time my LG dishwasher (LD-2120w) has code: F on then during a cycle it stops and flashes 0E. I have found OE means to clean the filter which i think i have done, but the priblem is...
With an OE error, the next step is to follow the drain hose from where it connects to the dishwasher through the point where it connects to the drain.
Look for crushed hose, kinked hose. Then look for a plugged drain connection.
Please report back what you find. There are other things that ~could~ cause the problem. OK?
Aug 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
407 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
