Question about Husqvarna Garden
Mountfield lawnmower leaking fuel into air filter
  • 37 Answers
SOURCE: mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Posted on Nov 23, 2008
  • 10865 Answers
SOURCE: what fuel do use in the mountfield HP470 petrol
No. This is a 4 stroke engine and it uses regular gasoline, not a mix.
Posted on May 06, 2009
mowerman1857
  • 389 Answers
SOURCE: how much oil does a mountfield omega lawnmower take
If it is a small horsepower engine 4, 5, 6 HP, it will take approximately 20 ounces. If it is a larger engine8, 9 ,10, 11, 12 and on up it will take from 40 to 48 ounces
Posted on Sep 15, 2009
mowerman1857
  • 389 Answers
SOURCE: sears lawnmower model 917387272
Unless someone has modified it, there is no fuel filter. The fuel tank is coupled direct to the carburetor by a short piece of hose.
Your running problem is most likely due to (dirt and/or moisture) contaminated fuel in the float bowl. You will need to remove the float bowl and clean it out and clean the carburetor main jet at the same time
Posted on Oct 31, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Engine starts cutting back and
Check/Clean/Replace your fuel filter if you have one.
If the mower/weedeater/edger is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 20, 2011
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
Lawnmower leaks fuel where air cleaner is
The only way fuel can leak into the filter is if the carb needle is not seating correctly, this may be due to dirt in the carb, or the inlet needle inside the float bowl requires replacment,
Jul 07, 2012 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
How do I change a worn Carburettor Gasket and Diaphram on a SP470 B&S Engine on my Mountfield Lawnmower? I'm good at DIY. The engine is hunting and running erratically.
Hunting and erratic operation are signs of air leaks or diminished fuel flow at WOT settings.
If this mower is running a vacu jet style carb with a diaphragm you simply take off the air cleaner, the vent tube, and then the four screws holding the carb on the gas tank and after the carb body can be lifted remove the throttle linkage so you can flip over the carb and pull the main jet and clean the inlet screens.
http://www.psep.biz/store/briggs_stratton_carburetor_kits.htm
Aug 11, 2010 | Briggs & Stratton Garden
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Fix scott bonnar lawnmower Prisma 37 model
Start by replacing the fuel filter and connecting hose at the leak point. It is important to use "fuel hose" and fuel hose clips - which are different to standard hose clamps.
If you have problems with mice - use a steel braided fuel hose - as they can't chew through these ! -
http://www.vehicle-wiring-products.eu/VWP-onlinestore/hoses/hoses.php
May 14, 2009 | THQ The Lawnmower Man
What fuel do use in the mountfield HP470 petrol lawnmower is it a 2stroke mix?
May 06, 2009 | Garden
Mountfield sp470
Nov 20, 2008 | Garden
Petrol lawnmower cutting out.
try changing the spark plug. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal.
Aug 29, 2008 | Garden
Garden Logo
32 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
