Question about Toshiba Satellite A105 Notebook
Laptop problems i am having problems with my laptop freezing up and rebooting by itself. Sometime when I push my power it click and does this for about twenty or sometimes less.
  • 1,006 Answers
This error can be caused by one or more of the below possibilities:
1:) Virus ( witch antivirus do u use i recomended you to use sophos for me is the best one and if u want i will post here for you)
2:) HDD problem
3;)OS PROBLEM ( this one u can fix when you use ORIGINAL CD AND REPAIR IT )
Let me know if u got help
Posted on Nov 02, 2007
Laptop freezes occasionally...
Download and install the FREE version of Malwarebytes (linked below). Check for and allow it to install an updated definition file. Scan the PC and delete / quarantine any adware / malware / etc. found. Reboot and repeat. Make sure you have an antivirus running too - Security Essentials from Microsoft is also linked below.
Malwarebytes Software
Microsoft Security Essentials
May 18, 2015 | Computers & Internet
How do I stop Skype freezing oon my laptop ?
Try This:
CTRL+ALT+Del this will open Windows Task Manager Under Application tab right click on Skype and left click on "Go To Process"
Left click on End Process. this will stop Skype without rebooting the PC.
After opening Skype does ALL programs Freeze? If so then its probly Malware running on the PC.
Reboot the PC into safe mode and run a full scan with your antivirus program.
Good Luck!
Aug 19, 2012 | Acer Aspire One PC Notebook
Very slow, freezes, jams, and is non responsive, I have to take battery out and wait for a an hour before putting battery in laptop, my computer is an acer 2350 travelmate, also when I bought this in...
This sounds like either a hard drive problem, when you power on the laptop there should be an option to enter BIOS or Setup (usually F2) once inside of the BIOS you should be able to run a diagnostic. and that will tell you if there is anything wrong with the hardware. If everything passes that test. you may have some serious Virus problems.
May 04, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
My computer runs window 7 and it keeps shutting down for no reason and also it keeps freezes for sometime.
Reboot the computer in "Safe" mode and run it for a while and see if the same problems occur. If it doesn't, then I would suspect it is a software and not a hardware problem.
If you think it is a software problem, reboot the computer into safe mode again. Now click the start button and in the search box type MSCONFIG
When the window pops up click the "Selective Startup" button and then on the startup tab. Deselect all the checked boxes, click apply and ok, reboot the computer normally.
Now only the essential services will load and no programs will automatically load. If the computer continues to run normally, then you can go back into MSCONFIG go to the strat tab and start checking a few boxes to start again, like antivirus and malware first. Reboot the computer and see if it freezes with those programs running....if it does then you know one of those is the culprit, if not click a few more on and reboot until you find the trouble software.
Jul 01, 2010 | Computers & Internet
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
I have the same problem with Stand by on my IBM Thinkpad
Try going to performance and maintenance then power options.Make sure the power scheme is set to Portable/Laptop.Make sure all the drop down boxes are set to NEVER.Go to the hibernate tab and uncheck Hibernate.Be sure to push apply.Then reboot.That may stop your problem.
Aug 07, 2009 | Toshiba Satellite M100 Notebook
Screen shakes and it freezes
i suspect a possible loose contact between the ribbon connecting the motherboard module to the LCD display module. if you can open up the laptop, check if the both the ends are snug and tight.
Mar 19, 2008 | IBM ThinkPad T42 Notebook
My compaq laptop freezes after 30 minutes
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. Have you expierenced that problem also? There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | HP Compaq nx6110 PC Laptop
Dell memory Dimm B errors, 2 gig memory upgrade
Can your laptop support 2 gigs?
Also, are you using the right memory for your laptop?
Nov 15, 2007 | Dell Inspiron 6400 Notebook
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
