These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
Only get Welcome screen and green blinking lite. Then shuts off. Buttons locked out also. Need to get software update V41C-11.3 Mitsubishi-tv.com. Go to support then software update. It will ask for model, ser. First and Last name and E-mail. download. http://www.avsforum.com/avs-vb/showthread.php?p=19844230 Has a link about 1/3 way down that will go right to the download. Very helpful.
When the power
light comes on and goes off, on the front of the set press BOTH the
Menu and Input (Device) buttons at the SAME time and HOLD them both for
at least five seconds and then release both.
The power light
will blink a two digit error code and will repeat it about 5 times. To
get it to repeat you would have to unplug the set and turn it on again
etc.
The most common error is 2 blinks, pause, 2 blinks.
Let me know what error code you find and I will direct you as to what it means and what may have to be done.
Replace the dm power board . Its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002 Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16v.
Can you give a little more information? Did the Laptop Fall? What Color is the light that blinks? Amber or Green? So far it Sounds to me that you Power Supply is Dead or Bad and or not charging the Battery....
First Check the battery status light? Is the Power Supply Light (Lite). you might want to try removing the battery and using only the Power supply!
