My TV doesnt turn on. where is ther fuse?
The fuse should be near where the line cord is attached to the power supply inside the TV. Be careful as there is a possibility of some DC voltage present from filter capacitors still holding a charge, long after the set is unplugged. If a fuse is blown and blackened, a new fuse will probably do the same when the set is plugged back in. Make sure you use the exact same rated fuse. IF the new fuse blows right away, do not repeat the process, it will only cause more damage. Good Luck.
