Question about Nikon D80 Digital Camera with 18-135mm Lens
Slow shutter My camera, suddenly, developed a slow shutter. Is there a setting that might have inadvertently been changed to cause this?
SOURCE:
SOURCE: Not able to change flash setting - button not working
This worked for me. Thanks.
Posted on May 29, 2007
  • 17 Answers
SOURCE: Is there anyway to resolve shutter lag on the Nikon Coolpix 8700?
oh what mode is your camera in? auto- adjust your Iso it is too bright or dark for your current setting
c1-(manual) change your f-stop and Iso. set the iso to 200 and move the F-stop to any number and test the speed.
c2-same as c1
If you need further clarification write back i'd love to help!
Posted on Mar 12, 2009
SAFFOTO
  • 78 Answers
SOURCE: D300 long shutter delay
are you using mirror lock-up or live-view feature?
Posted on Jun 14, 2009
HyeProfile
  • 35 Answers
SOURCE: Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Posted on Aug 05, 2009
SOURCE: shutter speed on my nikon d80 is to slow
Try CUSTOM SETTINGS MENU 31. (turn off EXP. delay mode).
Posted on Dec 11, 2009
My shutter speed is very slow and when I take pictures I think when it's dark is when I notice the problem but the picture will not take. Also if someone moves their face is blurry.
What mode are you shooting in? It seems you may either have your shutter speed set manually to a slow speed or, alternatively you have set your apperture set to a high number e.g f/20 or there abouts. Because this is a very narrow apperture the camera will compensate by using a slow shutter speed.
Try some shots in fully automatic mode and see what happens. With a slow shutter speed you can expect any movement to produce blurred images.
Oct 21, 2011 | Nikon D90 Digital Camera with 18-105mm...
Our D60 used to take great pictures. I only use it on Auto since most are pics of people or still objects and really I don't know to use all the settings. All of a sudden, the shutter speed is now very...
The pictures are blurry due to camera shake, which in itself is caused by the slow shutter speed. Try using shake reduction setting. To increase the shutter speed, raise the ISO rating.
Sep 06, 2017 | Nikon D60 Digital Camera
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
Shutter slow, pictures blur if not on solid object. Exposures OK.
This is a common problem if you are taking pictures in low light with out using the flash.
I suggest to set all settings in your menus to factory settings. Then set them the way you want. This may change some settings.
Always either have the camera on a solid surface or use a tripod when you take slow shutter pictures without the flash.
Oct 19, 2009 | DXG Technology DXG-503 Digital Camera
Konica Minolta X-370 Wont develop
Two possibilities : 1 ) your film was not properly loaded into the pick up spool and hence it was transported or exposed ; what you took to the lab was unexposed film. 2) the shutter is not opening and again no exposure takes place. To check this open back , set to slow speed like 8th of a second, and see if the shutter opens and closes properly. If the shutter does not open then it will have to go in, unfortunately. Cost ? If it is just an adjustment ( as I suspect is the case ) you should not pay more than $ 100.
Nov 01, 2007 | Minolta X-370S 35mm SLR Camera
Indoor flash images are blurry
It is possible you have the Flash Mode set to one of the Slow Sync modes (lighting bolt with the word Slow). Slow synchronization flash sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should use the FILL-IN FLASH (single lighting bolt symbol) mode for most situations that require a flash for correct exposure. Repeatedly pressing the FLASH MODE button will cycle through the various flash mode settings.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Flash images are blurry
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Images are blurry
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Nikon D80 Digital Camera with 18-135mm Lens Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
