Question about Bunn GRX-B
Does not warm the coffee - Bunn GRX-B
Coffee not staying hot. How do I get the base to stay hot?
Hello, Tam -
The warming element in the coffee maker base may be faulty (no longer working.) Eventually, heating elements can fail.
You do not state the make and model of your coffee maker, nor do you state how old the machine is.
Depending upon whether you wish to test the warming element to determine if it is no longer working or whether you choose to take the machine to an authorized repair center and depending upon the cost of replacing the warming element, you may choose to just purchase a new coffee maker and send the old one to proper electronics recycling.
There is information here on how to test a coffee maker warming element to determine if it is working:
https://home.howstuffworks.com/how-to-repair-small-appliances3.htm
Look for the section headed "Servicing Warming Elements."
Best wishes.
Jan 21, 2018 | Coffee Makers & Espresso Machines
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
Coffee pot turns off after brewing
This is the correct operation for this type of coffeemaker. It uses the thermal carafe to keep the coffee warm after brewing, and doesn't use power to operate a warming plate
Oct 04, 2011 | Mr. Coffee 8 Cup Thermal Carafe...
Won't brew
I assume your talking about a coffee maker, your most likely going to have to take it apart, there may be a loose connection somewhere inside the coffee maker. You will have to solder or reconnect a wire somewhere, coffee makers arent exactly complicated so you shouldnt have a problem.
May 19, 2009 | Mr. Coffee ISX23
Water comes out warm, not hot
may i try and help you. you may have a machine that only makes coffee lute warm. try and warm the cups before hand.
May 04, 2009 | Bunn VPR-Black (33200.0001) 12-Cup Coffee...
Cold coffee
Is it the coffee maker itself or the warming plate?
If it's the warming plate I would suggest geting a coffee thermos similar to the ones they have at IHOP and other breakfast places, it will keep your coffee hot all day if you first heat it up with very hot water and your coffee will not have the burned taste
Please answer if the answer works for you, thanks
Feb 13, 2009 | Cook's Essentials CEMB10TC
Use of warm water
Warm water is said to contain more impurities than cold water, like lead. Warm water takes more lead from your home plumbing, than cold water.
So it's not advised to use warm water for boiling...
Mar 27, 2008 | West Bend 13500 Coffee Maker
Coffee not hot enough
http://www.amazon.com/Hamilton-Beach-Coffee-Thermal-Carafe/dp/B0000W4N0G
This page has alot of info about this coffee maker.
There is customer feedback here too.
It may answer your question.
Feb 13, 2008 | Hamilton Beach Stay or Go 45235G 8-Cup...
Warming tray too hot
You can either replace the warming element with a new one, or some people put 3 or 4 pennies on the top of the warmer tray. Don't laugh- this really does work!
Feb 08, 2008 | Bunn VPR Coffee Maker
Warmer stopped working
the coffee maker brews but the pot warming plate isn't hot
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Bunn GRX-B Logo
35 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
