Question about Audiovox Audio Players & Recorders
Radio works only on preset - Audiovox Audio Players & Recorders
Bauhn ADR-6R
Manually tune to a station and hold a knob until it beeps. Do the same for all presets.
Jun 04, 2014 | Pure Digital The Bug DAB Radio
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Jun 28, 2010 | SanDisk Sansa e250 MP3 Player
Radio Installation procedure
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the working Code Entry Instructions if the Renault does NOT have the Steering wheel Remote Control
Keep pressing the Preset [1] until the correct first digit appears on the display
Keep pressing the Preset [2] for the correct second digit
Keep pressing the Preset [3] for the correct third digit
Keep pressing the Preset [4] for the correct fourth digit
If the correct code is now shown on screen, press and hold the Preset [6] for 10 seconds to save it.
Note: If Preset [6] does NOT enter the code , then try Preset [5]
Jun 06, 2010 | Car Audio & Video
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
How do i put the code into a vauxall astra radio
Switch the ignition ON using the key
Switch Radio ON - Display Shows CODE with " - - - - " flashing
Press Preset Button " 1 " repeatedly for 1st Digit of your KeyCode
Press Preset Button " 2 " repeatedly for 2nd Digit of your KeyCode
Press Preset Button " 3 " repeatedly for 3rd Digit of your Keycode
Press Preset Button " 4 " repeatedly for 4th Digit of your Keycode
If the display now shows the correct KeyCode number then
Press Preset Button " 5 " to Enter Providing your KeyCode was correct then your radio / cassette or CD should now be working
Oct 07, 2009 | Car Audio & Video
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Sep 04, 2009 | Infinity Reference 1211a Car Audio...
Preset Radio Statios
I just dug out the manual and have now programmed a preset.
Instructions:
1) Make sure there are a pair of working AA batteries behind the second (inside) compartment door as these power the memory (mine were Duracells with an expiry of 2001 and had worked all the way through to 2010 before finally failing!)
2) Find the frequency you want with the Up/Down button
3) Press the M button - you will get a flashing M on screen
4) While the M is flashing, press one of the numbered preset buttons.
Jun 23, 2009 | Audio Players & Recorders
Radio preset buttons not working
you can take it to your mechanic. you might have to replace the entire radio set though
Jun 11, 2009 | 2006 Saturn ION
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Ive got a factory radio reading of i have code how do i reset to put in code
When you turn on the radio, it will say "codE" on the display. You have the 4-digit code number for your radio, to enter the first digit, press the "1" button on the radio the number of times until the first digit matches. For example, if your code is "2156" then, press radio preset button 1 two 2 times, then press radio preset button 2 one time, then radio preset button 3 five 5 times and finally preset button 4 six times.
THEN if the display is correct (should show 2156 in this example), press TAPE button. You should hear a beep and the radio should be working. If you make a mistake and enter a wrong code, the display will show "Err". You have 3 tries to get this correct or the radio may be toast. These are the steps for the stock radio in my 1995 GSX and they've worked for me each time I've lost battery power. Good luck!
Apr 09, 2009 | 1995 Mitsubishi Eclipse
Top Audiovox Audio Players & Recorders Experts
John
John
phil
Andrew Taylor
Andrew Taylor
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
