Question about HVLP Air Tools & Compressors
Triger not working - HVLP Air Tools & Compressors
I have a miller 255 nig .the welder will start to weld and stops gas flow is working the triger is working . You can relase the triger and start it again it willweld about 1 inch and stop emall ...
Sound like you have a machine programed on stitch mode, to override the program do the following:
1)Turn off the machine
2) With the machine turned off press the gun trigger.
3) Turn on your machine keep the trigger pressed, hold it for about 3-5 seconds. Depress the trigger and you should be good.
Jan 03, 2011 | Miller Welding Tools
Bad Triger on craftman electric drill, were do I get one triger
I would go to Searspartsdirect.com and using your model number look at a breakdown for this tool and order it online from them direct
Nov 21, 2009 | Craftsman C3 19.2 volt Combo Kit,...
How do i clean a springfield model 67e 20 ga shotgun? I do not see an easy method of removing the triger mechanism.
dont,,,,just dont,,, remove the triger and you should never oil a triger any how, it could cause them to fire off when you least wont them to,,and bullets kill you know? so its realy is best not to take the triger to bits,,,i give mine a quick splash of wd40 every 5 years or so??? or after 3000 rounds have been fired
just cearfully swob the barrel out and dry it well then oil the out sides and the wood work, job done then
Nov 20, 2009 | Optics
How do i remove the bolt from the mossburg 308 win. and is there a product you offer to modify the triger
if i were you i would leave the bolt alown,,its a hell of a job getting them back in,,,as for the triger i know there a bit on the heavy side to pull at nearly 4 lbs but its a safe pull,you could drop the gun into a gum smith and get him to snip off a coil off the triger pull spring,,and stone the sear,, but be warned it will make the triger twitchy,,you realy dont wont to light a triger on a hunting rifle 4 - 6 lbs is normal
Nov 18, 2009 | Optics
Doe it work with a cactus triger
Yes, no problem. Just check trigger voltages. a.l9609@gmail.com
May 22, 2009 | Vivitar 283 Flash
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Sep 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
22 people viewed this question
Top HVLP Air Tools & Compressors Experts
john h
russ davis
Steve P
Steve P
Are you a HVLP Air Tool and Compressor Expert? Answer questions, earn points and help others
