Question about Coffee Makers & Espresso Machines
Astra overheating problem
Fan only switches on at three quarter mark on heat gauge. already replaced fan switch, thermostat as well as flushed the radiator. fan used to switch on at halfway mark on heat gauge.
emissionwiz
  • 76848 Answers
SOURCE: 96 Blazer Overheating
Yes the issue is most likely an air block, jack the front of the truck up as far as you can, fill the recovery bottle and run the engine for about 10 min, then shut down and run cold water over the radiator, this should purge the air, recheck the recovery tank and refill as ness.
Posted on Oct 30, 2008
SOURCE: My Jeep overheats while sitting idle. When I drive, the gauge goes down quickly. I have had thermostat and fan changed. I have also had the radiator flushed. What can it be?
we have a 2003 and it did the very same thing . Its called cooling fan relay it costs about 60.00 and is located behind the headlight assembly . not very hard to fix if you know anything about cars .
Posted on May 07, 2009
  • 4 Answers
SOURCE: overheating 94 saturn sc
Check the upper radiator house. When the engine is cool this hose is cool and soft to a squeeze pressure. If you check the same hose while the engine is hot "use caution as this hose might be very hot" this hose shoud be hot and stiff to the touch (louded under pressure). Lack of either is normally a sign of a bad thermostat or a failing water pump. Also check that the water reservoir cap is not leaking, is only a $5 fix.
Posted on Dec 24, 2009
  • 189 Answers
SOURCE: Switch wiring
If you will get the model and date code from the bottom of the machine and contact customer service, we can further assist you.
Posted on May 19, 2010
  • 264 Answers
SOURCE: 1995 BMW 525I over heating issue. I repaired head
Hi, Sounds like you have tried about everything. Ok the aux. coolant switch is for the electric pump for the heater core will not cause an over heating condition just a longer warm up of the heater core. Has the cooling system been bleed properly if there is a trapped air pocket it will not let coolant circulate. Was the new thermostat installed correctly? They have a vent that needs to be towards the top or they trap air on the back side and cant take an accurate reading to open and close. Other areas to look at would be proper operation of the fan clutch, if they fail they can cause the fan to not lock up properly and supply enough air movement through the radiator. The aux. electric fans and their temp switches do you hear them coming on are they coming on at the right temp.
Posted on Aug 26, 2010
Car overheating when radiater full water
Have a coolant pressure test done looking for a head gasket problem. as well as the fan
May 18, 2013 | Toyota Cars & Trucks
99 pontiac montana overheaten already changed thermostat what is it?
you have a GM common problem and that is a bad intake manifold gasket. GM change the gaskets to plastic and they crank and leak causing over heating. here is a picture of one i took from a 2005 pon. bonneville with 74,000 miles on it2_12_2013_3_00_09_am.jpg
Feb 12, 2013 | 1999 Pontiac Montana
2004 nissan quest overheating a little
You can run the engine without the thermostat as a test.
Not recommended to run it forever like that.
The problem could be air in the system, or a faulty water pump not making the coolant flow.
Jan 24, 2013 | 2004 Nissan Quest
1.6i Bakkie starting to overheat gauge goes to three quarter mark
THE FIRST THING I WOULD DO IS HAVE THE ENGINE THERMOSTAT REPLACED AND INSOECT THE COOLINFG SYSTEM FOR CORROSION (DARK COLORED COOLANT OR SLUDGE IN THE OVERFLOW TANK.
Jul 12, 2012 | Cars & Trucks
Drained radiator added prestone Radiator flush refilled and started overheating, drained radiator replaced thermostat and now I get no heat from heater,Radiator water is hot
disconnect the heat hoses going into fire wall , put hose into one with pressure and flush as it sounds like it could be bloked in the heater core,the other thing that could be the problem be the hot ,cold switch as it restricts the flow to makes the heater hoter or colder , it might need tlc or replacing as it is manaul not elec
May 08, 2012 | 1995 Toyota 4Runner
'97 Pontiac Sunfire, 2.2L, se (Base model, no power options.), 5 spd manual, coupe, 185,000kms on it. Car heats up to three quarters on gauge during idle, sometimes 9/10ths (sitting in traffic, etc.)...
make sure the fan works first ,, jumper 12 volts to it, and see if it even runs,, if it does,, check the fan relay ,, which should be in the under hood fuse/relay box,, you need that fan working to keep the temp down. , once thats taken care of, flush the system using a radiator flush additive,, ( save yourself some money and do this with just water, No need to waste antifreeze) once thats done, fill it again with a 50'/50 mix,, remember,, antifreeze breaks down just like the oil in your motor does, and needs changing one in a while . if you don't know for sure that the thermostat was changed, change it,, for less than 15 bucks its worth it,, instead of a new motor .
Sep 24, 2011 | 1997 Pontiac Sunfire
Overheating
According to my owners manual the following items should be checked.1coolant level 2 faulty temp gauge or gauge sensor 3 thermostat stuck in the closed position 4 faulty rad cap 5 blocked water passages in rad,hose,or engine 6 fan blades cracked or missing 7 faulty fan motor 8 improper ignition timing 9 improper spark plug heat range. I think I would start by replacing the thermostat after a good engine flush and replacing the coolant.Good Luck
Nov 25, 2010 | 1986 Honda GL 1200 Aspencade Gold Wing
HI. MY CADILLAC SEVILLE V8 4.9L '93, STILL OVERHEATING. I REPLACED: NEW RADIATOR, FAN MOTOR, THERMOSTAT, WATER PUMP. SOMETIMES DRIVES GOOD AVERAGE 180 DEGREES, BUT AT NOON INCREASE 240, 255. I DONT KNOW...
Ensure motor tune or other motor mechanical condition is not the cause of overheating, I assume the motor is actually running hot, - ensure the high gauge reading is not just a gauge sender problem. Check cooling fans are operating ok (as necessary when car warms up):- if not check
1) fuse,
2) relay operation,
3) heat sensor switch.
Check the coolant pressure cap is serviceable & of correct rating,
Ensure cooling system is correctly filled, bleed off any airlocks as necessary when re-filling,
Ensure radiator hose on suction side of waterpump is not collapsing at engine revs above idle (due softening),
If the motor has been severely overheated, the head gasket could be blown - look for combustion gas bubbles in the coolant resevoir.
If none of the above fix your problem, replace the thermostat again - it is not unheard of for a new thermostat to be faulty .
Sep 03, 2009 | 1992 Cadillac Seville
Temperatue gauge needle position
180 degrees. Usually the middle.
Jul 03, 2009 | 1996 Ford Taurus
Overheating
Your overheating problems can have several possible causes.
1) Airlock in heating system - solution - bleed air from cooling system.
2) Radiator blocked - solution - drain and flush radiator
3) Failed waterpump - solution - fit new waterpump
4) Engine thermostat stuck in closed position - solution - fit new thermostat
5) Electric cooling fan (if fitted) failing to operate - solution - check fan, fan operating switch, all wiring and connectors
6) Not enough coolant in system - solution - check and top up to required level. Also check all hoses for sign of leakage.
7) Faulty temperature gauge giving incorrect reading.
Jun 21, 2009 | 2001 Jaguar XJ8
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
