Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Magnavox 35 inch will not turn on - Pioneer SD-P50A5-K 50" Rear Projection Television
How do I download Hulu on my 50 inch magnavox smart tv?
How to Stream/Watch Netflix, Hulu and Pandora on Your TV ...
? 2:43
https://www.youtube.com/watch?v=ZAA2SSOXXpI
Nov 4, 2011 - Uploaded by Howdini
http://bit.ly/pva2jr How to Stream/Watch Netflix, Hulu and Pandora on Your TV Technology Guru, Veronica Belmont, shows you a simple and inexpensive way to en... ... 14:50. NEW! $49.99 Roku Streaming Stick 3500R Unbox and ... Setting up and streaming Netflix / YouTube to my Google Chromecast!
MAGNAVOX 2014
www.magnavox.com/support/news.php
Magnavox+ TV · + Player · + Home Cinema · + Contact. Magnavox...Smart. Very Smart. News.Magnavox Unveils Superior Sound with the World' s First Expandable Soundbar ...Soundbar fit perfectly underneath a 32 inch-46 inch television and even some larger sized units. ... Now Hulu Plus is in our HD Streaming Box TB600MG2F.Missing: my
50" Class 1080p LED LCD TV - Magnavox, Smart, Very .
Dec 21, 2015 | Televison & Video
Magnavox ms 3252s431 Bad picture and turns off by itself
Hello, Change horizontal driver buffer transistor's and capacitor's. 7461 7463 transistor's. Caps 2455 2405 near transistor's. Please leave your email address, I will try to find the service manual for you. Best regards, Arpi
Jul 26, 2007 | Philips Magnavox MS3252S 32" TV
I have sound but no picture screen is black 19inch screen
I cannot say enough about this model. There is a bad capacitor or two in this set. You should be looking for a buldged cap at maybe 25 or 35 volts at 2200Mfs. Replace this and the next one near would be a 35 volt at 1200 Mfs. I have a question for you, if the model number is 42 MF, the screen is large. And yet you say it has a 19 inch screen. I'm not sure if you have the large TV or the small TV. The answer I give you is for the large screen. Hope this helps you! Thanks for asking and show a few hands of support!
Oct 07, 2010 | Philips Magnavox 42MF521D/37 Television
Magnavox plazma 50 inch flat screen wont turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Televison & Video
Magnavox 42 inch flat panel cannot get a picture
TV may need software upgrade. Go to menu, find instalation, find software upgrade, find. If version is bellow FL2D-r23 (#23) TV needs upgrade.
Get upgrade on the internet onto a USB flash drive. The file may be a ZIP file, if so, unzip to a folder in PC then put the file to the USB drive.
Turn TV on, plug in the USB drive, wait til the upgrade is finished. Unplug USB drive, turn TV off w/remote.
The TV will then turn on by its self and the upgrade is complete.
Hope this works
Sep 27, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Can only get channels 1-13,can't get the cable channels
Press Menu
Scroll right to TUN (Tuner)
Scroll down to TV/CABLE
Toggle from TV to Tuner
Problem Solved
Feb 15, 2009 | Philips Magnavox 27MS343S 27" TV
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
15 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
