Question about Dryers
Unstacking stacked washer dryer How do I unstack a samsung dryer model # DV203aes/xac There are no visible screws or caps. Can anyone help??
Need to remove dryer from washer to recycle.How do I unstack samsung dryer model # DV203aes/xac
2 Suggested Answers
SOURCE: How to unstack a dryer
I have a Kenmore 417.69042990 stackable dryer and had a similar problem. To unstack it, in the front of the dryer there are two screws that are covered by round caps. They are easy to miss unless you look for them. Remove the caps, and the screws underneath it. Now, voila, you can lift the front of the dryer and pull as to unlock it from the two brackets in the rear of the dryer. Hope this helps... I took me and my husband over an hour to figure this out...
Posted on Sep 29, 2009
How to use stackable washer and dryer if unstacked
stacking was just a gimmick to save space
put the drier on a suitable stand , table or it is possible that there are holes in the back section for a mounting bracket to hang it on a wall
Sep 30, 2016 | Washing Machines
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
I need to unstack my kenmore washer/dryer
On the model posted this style does not come apart. Only on the front load style can you seperate them.
let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Kenmore 98702 Stacked Washer/Dryer
I have an Electrolux stackable washer and dryer. Model: MEX 731CAS3 It is in a tight place but I would like to pull it out and "unstack" it for removal and sale. Does anyone know if indeed, the dryer...
Typically stacked washers and dry are attached with a bracket in the back of the machine. Pull your machine out and you should see the brackets. Undo the screws and the dryer should lift off the washer.
Aug 23, 2010 | Washing Machines
Thanks I thought it might be the inlet valve, but to get access to it behind the top panel, Is there a trick to removing the panel? I have removed the three screws behind the detergent drawer but the panel...
Hi, you will need to unstack the dryer unfortunately, then remove the three screws at the back of the top washer panel and it will slide back about 2 or 3cm and up away from the unit. Then you will see how to remove the valve. Hope that answers your question. Thanks for visiting "fixya". Let me know if you require any further assistance and good luck. Macmarkus :)
Jun 17, 2010 | Asko W6021 Front Load Washer
Remove front of LG DLE3777 Dryer
The dryer front is usually held on by two screws in the cabinet just under the top of the dryer. Yes, they'll have to be unstacked and the top on the dryer popped loose to access these screws.
Apr 04, 2009 | LG DLE3777 Electric Dryer
Hello, I have a stacked Whirlpool washer/dryer. (Model # LTE6234DQ1) I wish to move it down a flight of stairs and want to know if this model can be easily 'unstacked' for the move. Thanks for your...
Hi there.
Yes it can.
Access bolts to the feet should be visible from the rear of the unit. Failing that, the top screws of the bottom appliance should undo, and the top appliance (with lid of lower one) should slide back 1" allowing it to be taken off.
Be careful not to damage this lid section in the move, and further removal can restore it back to two appliances again.
If this helps, Please take a moment to rate as Fixya! Thanks.
Jun 17, 2008 | Whirlpool Washing Machines
Nov 11, 2007 | Dryers
HOW TO UNSTACK A WASHER AND DRYER
Chainsaw, no seriously the dryer is bolted to the washer and not all of them can be unstacked. Remove the front panel of the dryer to expose the bolts holding it down. this only works if your washer is of the front loading type. if it is a top loader there should be some sort of frame the dryer is bolted to. after removing the dryer from a front load stack washer, the washer may or may not have a top panel on it
Sep 02, 2007 | Dryers
Dryers Logo
268 people viewed this question
Top Dryers Experts
