Question about Danby DDR401 Dehumidifier
No water in the bucket - Danby DDR401 Dehumidifier
Flashing light is on(power on/off pad)
red lights on dehumidifiers almost always indicate a full water catch bucket , this does not allways mean it's actually full of water , the machine thinks it is , some thing has gone ary with the level sensor in bucket , these most times are a simple float switch, that can get knocked out of position when one is emptying the bucket , also this same float switch also allows machine to know there's a bucket in place to catch water , sometimes bucket is not in correct place to catch water so machine wont start
May 26, 2015 | Amana D945E 45 Pint Capacity Dehumidifier
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
Dehumidifier stopped working because "water bucket full" indicator light stays on, although there is no water in bucket.
In the water bucket is a float assm. scale forms on the assm. and causes it to stick. Remove the float assm. and carefully remove the scale. Should start working again once done. If not you may have to replace it.
Mar 11, 2013 | Dehumidifiers
Dehumidifier smells stinky
Have you read its manual? http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
It says (p8):
Care and Cleaning
1. Filter
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, then replace Bucket.
2. Cabinet
a. Dust cabinet with an oil-free cloth, or using a damp cloth.
b. Vacuum grill using brush attachment.
3. Water Bucket
a. Clean bucket with warm water and detergent.
I recommend you to use a mix 75% water, 25 % vinegar. To clean its water bucket.
Oct 01, 2012 | Frigidaire FDF70S Dehumidifier
Overflow on floor
The problem you're having can be caused by a couple things.
1. The float valve in the top of the water collection bucket is broken or is stuck in the Down position.
Remove the bucket, and inspect the float valve for damage or sticking. If it's stuck in the DOWN
position, jiggle the arm of the float valve, to make it works freely.
2. The water collection bucket is not installed properly and water is leaking out the back of the
top of the bucket. When installing the bucket, be sure it's installed "squarely" into the bucket
holder from top to bottom and making firm contact with the bucket safety removal switch on the
rear wall of the bucket holder.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 15, 2011 | LG DH30 GoldStar Dehumidifier
Are you supposed to put water in the bucket of the dehumidifier or is the water that is in the bucket now from using the dehumidifier? Dumb question I am sure. But I am renting and have never used one...
The dehumidifier condenses the water on its coils and then it drips into the bucket. Dump out all of the water when the bucket is full. This model has a light that tells you when it is full. If the dehumidifier gets ice on the coils, it needs repair (low refrigerant).
I hope this helps.
Aug 10, 2009 | Kenmore 54701 Dehumidifier
Dehumidifier not sure is working
There is water in the bucket or no water in the bucket? If there is water in the bucket then empty it and put it back. If there is no water in the bucket then make sure the bucket is all the way in, (there is a switch that senses the bucket). If the bucket is not all the way in the de-humidifier will not work. If you do not hear it, it is not working.
Jun 21, 2009 | Dehumidifiers
Water bucket - proper seating
Try re-seating the bucket. I have found some LG models that if not seated all of the way will sometimes keep running and think the bucket is not full even when it is. On the models that I have seen do it the problem is usually the left side of the bucket not engaging all of the way. When you reseat the bucket, feel where the bucket meets the dehumidifier on each side and make sure they are even. If one feels like it is sticking out further than the other and you cannot push it in any more pull the bucket out and try and reseat it again until both sides are flush with the dehumidifier. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 10, 2008 | LG DH404E Dehumidifier
Danby DDR401 Dehumidifier Logo
80 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
