Question about Garden
How do i change shaft oil seals on a sears tiller model number c917 29258
4 Suggested Answers
  • 246 Answers
SOURCE: Change oil seal troybilt proline tiller
Hello pajaro646464:
Usually Yes you do.
Would Looking at a Breakdown Help?
You can View a Breakdown/IPL of this Unit at this Site Addy, http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_TroyBilt_10101_19502_-1 and Select Use Our Detailed Parts Finder. Then Enter the Model Numbers.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
  • 23 Answers
SOURCE: oil seal for rear tine shaft
I checked my troy bilt and can not find any numbers above the wheel on the housing and I know they have not been taken off. Is there anywhere else to look?
Posted on Jul 04, 2010
  • 277 Answers
SOURCE: need belt and bushing seals for (tiller)
try looking for tiller model 410 or 420
#215-410-019
the 135202 number is the b&s motor number
Posted on Feb 20, 2011
How to R&R the oil seals in the chain gear box on the side of the tiller
Ron, Re POST year, make, model, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Garden
The oil seal where the tiller attachment fastens to the tiller is leaking how do i remove the seal
IF THIS IS A WALK BEHIND TILLER OR FRONT TINE TILLER. THERE SHOULD BE PINS OR BOLTS HOLDING THE TINES ON THE DRIVE SHAFT REMOVE THESE AND PULL THE TINES OFF THE TILLER. THEY MAY GIVE YOU A HARD TIME GETTING THEM OFF SO DON'T GIVE UP. ONCE YOU GET THE TINES OFF YOU SHOULD SEE THE SEALS YOU CAN POP THE OLD ONES OUT WITH A SCREW DRIVER CLEAN OUT THE SOCKETS WHERE THE NEW SEALS WILL GO REPLACE THE NEW SEALS GENTLY WITH A SMALL HAMMER TAPPING THEM IN EVENLY AND TRY NOT TO BEND THE SEAL
Feb 05, 2011 | Garden
I have a 5 hp troybilt pony tiller. The axle seals need replacing can you describe the best way to replace them. This tiller was built in Feb. of 1990.
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in PONY for your model number and find your operator manual by your serial number. The operator manual should have detailed instructions on how to replace your seals.
On the Horse model you remove the wheels and then carefully use a couple of screw drivers to pry out the old seals being careful not to scratch the wheel shaft sealing area. Then polish the wheel shaft with fine emery cloth to remove any sharp edges. Then grease the wheel shafts and carefully slide the new wheel seals on and use a piece of plastic PVC pipe cut square that will slide over the shaft and gently drive the seal to the depth the old seals were installed at. You dont even have to drain the gear oil. Getting the wheels off the wheel shaft is sometimes a problem if they are rusted on. if you can get the wheels off its not to hard to change the seals.
Frank
Sep 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Nov 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Hello pajaro646464:
Usually Yes you do.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Leaks oil around the tines.
 an new oil seal needs to be put onto the output shaft of the transmission.  remove the plug wire if you attempt to pry out the old seal and tap in the new seal.  Be careful not to damage the case and grease the seal and shaft when you replace the oil seal
Mar 29, 2009 | Troy-Bilt Garden
My king kutter till will not hold gear oil.
If it is leaking around the shaft you can replace the seal.
Mar 23, 2009 | King Kutter II Gear Driven Rotary Tiller...
How to remove rear tines to replace seals ?
The tines sometimes get frozen to the shaft. You might try penatrating oil and use a heat gun or hair dryer to heat to loosen.
Also tap wiht a hammer around shaft.
Mar 19, 2009 | Troy-Bilt Garden
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
